How do I delete a user defined Kinetic Data View
Does anyone know how to delete a Kinetic Data View? I created a Data View as a test and don’t see an option to delete it.
In the left hand slide out pane that shows your data vies, right click on the dataview you created. The only option is Delete. This works for me! :slight_smile:
Unfortunately when I right-click on the view in the left panel - it does nothing…I don’t get an option to delete.
Ohhh I think I have seen that before! Try opening the browser version. You might be able to use right-click in the browser.
web browser didn’t work either :frowning_face:
Have you searched for your view name? After a search, the right-click doesn’t work. You cannot use the search if you want to delete. Same for the events and data rules.
Nope…did not search. I scrolled down to where my data view was.
did you find a solution to this?
Unfortunately no…I moved on and just left the data view in my custom layer but it is not used.
thanks
