How do I Launch selected serial numbers from customer shipment e
Yep!
After you declare the variable as you were doing above, you need to
populate it with the actual dataview so that you can lookup fields and such.
On Tue, Aug 14, 2012 at 9:55 AM, spmyers7582 <smyers@...> wrote:
> So by inserting the following line, am I assigning snsView?
> snsView = CType(oTrans.EpiDataViews("snsView"), EpiDataView)
> I ask as this has previously been tried without success.
> Thanks,
> Steve
> --- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> > You are declaring snsView but you are not assignnig it to anything.
> > Dim snsView As EpiDataView
> > *Jose C Gomez*
> > *Software Engineer*
> > *T: 904.469.1524 mobile
> > E: jose@...
> > http://www.josecgomez.com
> > <http://www.linkedin.com/in/josecgomez> <
> http://www.facebook.com/josegomez>
> > <http://www.google.com/profiles/jose.gomez> <
> http://www.twitter.com/joc85>
> > <http://www.josecgomez.com/professional-resume/>
> > <http://www.josecgomez.com/feed/>
> > <http://www.usdoingstuff.com>
> > *Quis custodiet ipsos custodes?*
Hi,
I want to know how to launch this form in code, following automatic
population of a new line. At present, my code errors out with the
following message:
'Missing or invalid parameter value: PartNumber..'
The code is as follows:
Dim PartNumber As String = dtl.dataView(dtl.Row)("PartNum")
Dim Qty As Decimal = dtl.dataView(dtl.Row)("OurJobShipQty")
Dim PackNum As Integer = dtl.dataView(dtl.Row)("PackNum")
Dim JobNo As String = Dtl.dataView(Dtl.Row)("JobNum")
Dim SNParams As New System.Collections.ArrayList
SNParams.Add(PartNumber)
SNParams.Add(JobNo)
SNParams.Add(Qty)
SNParams.Add(PackNum)
Dim lfo As New
Epicor.Mfg.UI.App.SelectSerialNumbersEntry.SerialNumbersArgs
lfo.valuein = SNParams
Dim SNlaunch AS UIReflector =
ProcessCaller.LaunchCallBackForm(oTrans, "ShipSSN", lfo)
Thanks for looking,
Steve
Are you sure those are the correct parameters to lounch Seria N0?
Which form ("DLL") are you launching.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Mon, Aug 13, 2012 at 11:47 AM, spmyers7582 <smyers@...> wrote:
> Hi,
> following message:
> SNParams.Add(JobNo)
> SNParams.Add(Qty)
> Dim lfo As New
> Thanks for looking,
> Steve
Epicor.Mfg.UI.SelectSerialNumbersEntry.dll
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi,
> > following message:
> > SNParams.Add(JobNo)
> > SNParams.Add(Qty)
> > Dim lfo As New
> > Thanks for looking,
> > Steve
Also, I'm not sure if the parameters are correct or not. The customisation help dialog does not give any clue as to what the arguments should be in:
This is why I've started to experiment with an array list, to no avail...
> Thanks
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@
> > On Mon, Aug 13, 2012 at 11:47 AM, spmyers7582 <smyers@> wrote:
> > > Hi,
> > > following message:
> > > SNParams.Add(JobNo)
> > > SNParams.Add(Qty)
> > > Dim lfo As New
> > > Thanks for looking,
> > > Steve
Its a lot more complex than you thought here is the general requirements,
are you trying to call the same code that epicor has? or your own custom
one? Here is what you have to do to replicate what Epicor does, ofcourse
you have to change to your objects.,
this.snsView.dataView.Table.Rows.Clear();
DataRow row = this.snsView.dataView.Table.NewRow();
row["ProcessToken"] = "Shipment";
row["GenericToken1"] = "ShipFrom=Inventory";
this.snsView.dataView.Table.Rows.Add(row);
this.serialSearchAdapter.SerialNumberSearch(this.serialSearchAdapter.SerialNumberSearchData);
string whereClause =
this.snsView.dataView[0]["WhereClause"].ToString().Replace("<<PartNum>>",
this.shipDtlView.dataView[this.shipDtlView.Row]["PartNum"].ToString()).Replace("<<WarehouseCode>>",
this.shipDtlView.dataView[this.shipDtlView.Row]["WarehouseCode"].ToString()).Replace("<<BinNum>>",
this.shipDtlView.dataView[this.shipDtlView.Row]["BinNum"].ToString());
int quantity =
int.Parse(this.shipDtlView.dataView[this.shipDtlView.Row]["DisplayInvQty"].ToString());
if (quantity != 0)
string transType = "STK-CUS";
string partNum =
this.shipDtlView.dataView[this.shipDtlView.Row]["PartNum"].ToString();
string sourceRowID =
this.shipDtlView.dataView[this.shipDtlView.Row]["RowIdent"].ToString();
bool showAsModal = true;
DataSet dataSet = (DataSet)
SelectSerialNumbersArgs.StartSelectedSerialNumbers(this, partNum, quantity,
whereClause, transType, sourceRowID, this.adapter.CustShipData,
showAsModal);
if (dataSet != null)
this.adapter.CustShipData.SNFormat.Clear();
this.adapter.CustShipData.Merge(dataSet, false,
MissingSchemaAction.Ignore);
if
((this.shipDtlView.dataView[this.shipDtlView.Row]["RowMod"].ToString() !=
"U") ||
"A"))
this.shipDtlView.dataView[this.shipDtlView.Row].BeginEdit();
this.shipDtlView.dataView[this.shipDtlView.Row]["RowMod"] =
"U";
this.shipDtlView.dataView[this.shipDtlView.Row].EndEdit();
*Jose C Gomez*
*Software Engineer*
E: jose@...
> > Thanks
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > > Hi,
> > > > following message:
> > > > SNParams.Add(JobNo)
> > > > SNParams.Add(Qty)
> > > > Dim lfo As New
> > > > Thanks for looking,
> > > > Steve
May I ask why you want to do this when you can pick serial numbers on the pack slip anyway?
If the part number is serialized all you have to do is click on the serial number button to launch it in the customer shipment entry screen.
M. Manasa Reddy
manasa@...<mailto:manasa@...>
630.806.2000 x1515
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of spmyers7582
Sent: Monday, August 13, 2012 10:47 AM
Subject: [Vantage] How do I Launch selected serial numbers from customer shipment entry?
Hi,
following message:
SNParams.Add(JobNo)
SNParams.Add(Qty)
Dim lfo As New
Thanks for looking,
Steve
Jose,
Many thanks for this code. I'm basically wanting the standard code behind the button, so it can be fired automatically if the part selected is detected as serial tracked.
I've been requested to make this process as seamless as possible for the intended users. Everything will be fired from the summary page, with the items required from the shipdtl screen being shown in a BPM form prompt. As stated, if the part is serial tracked, the serial selection screen will then appear from the summary page..
Needless to say, plain vanilla not palatable around these parts..
> int quantity =
> if (quantity != 0)
> string partNum =
> showAsModal);
> if
> "U") ||
> "A"))
> "U";
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > > Thanks
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > > Hi,
> > > > > following message:
> > > > > SNParams.Add(JobNo)
> > > > > SNParams.Add(Qty)
> > > > > Dim lfo As New
> > > > > Thanks for looking,
> > > > > Steve
Hi Jose,
I've tried to integrate this code but I'm struggling with the snsView. Is this an EpiDataView of Serial Number Search? If so, how do I point to that view when in custship?
Steve
> int quantity =
> if (quantity != 0)
> string partNum =
> showAsModal);
> if
> "U") ||
> "A"))
> "U";
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > > Thanks
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > > Hi,
> > > > > following message:
> > > > > SNParams.Add(JobNo)
> > > > > SNParams.Add(Qty)
> > > > > Dim lfo As New
> > > > > Thanks for looking,
> > > > > Steve
The SNSView is a Serial Number view which is available in CustShip, just
look at it in the wizard.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, Aug 14, 2012 at 4:41 AM, spmyers7582 <smyers@...> wrote:
> Hi Jose,
> Thanks,
> Steve
> > int quantity =
> > if (quantity != 0)
> > string partNum =
> quantity,
> > showAsModal);
> > if
> > "U") ||
> > "A"))
> > "U";
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> customisation
> in:
> avail...
> > > > Thanks
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > > > > > Hi,
> automatic
> > > > > > following message:
> > > > > > SNParams.Add(JobNo)
> > > > > > SNParams.Add(Qty)
> > > > > > Dim lfo As New
> > > > > > Thanks for looking,
> > > > > > Steve
Unfortunately, that must not be where I'm going wrong in that case. I'm
still getting the object reference not set to an instance of an object
error, so I'm guessing I'm forgetting to instantiate something...
Note this code is fired from an epiViewNotification of shipdtl. The
code prior to this populates the mandatory shipdtl fields.
Script:
Try
' snsView = CType(oTrans.EpiDataViews("snsView"), EpiDataView)
Dim row As DataRow = snsView.dataView.Table.NewRow()
row("ProcessToken") = "Shipment"
row("GenericToken1") = "ShipFrom=Manufacturing"
MessageBox.Show("Added Row")
SNSearchAD.SerialNumberSearch(SNSearchAD.SerialNumberSearchData)
Dim whereClause As String =
snsView.dataView(0)("WhereClause").ToString().Replace("<<PartNum>>",
Dtl.dataView(Dtl.Row)("PartNum").ToString()).Replace("<<WarehouseCode>>"\
Dtl.dataView(Dtl.Row)("WarehouseCode").ToString()).Replace("<<BinNum>>",
Dtl.dataView(Dtl.Row)("BinNum").ToString())
Dim quantity As Integer =
Integer.Parse(Dtl.dataView(Dtl.Row)("OurJobShipQty").ToString())
If quantity <> 0 Then
Dim transType As String = "STK-CUS"
Dim partNum As String = Dtl.dataView(Dtl.Row)("PartNum").ToString()
Dim sourceRowID As String =
Dtl.dataView(Dtl.Row)("RowIdent").ToString()
Dim showAsModal As Boolean = True
MessageBox.Show("SN Search")
Dim SSNArgs As New
Epicor.Mfg.UI.App.SelectSerialNumbersEntry.SelectSerialNumbersArgs
Dim dataSet As DataSet =
DirectCast(SSNArgs.StartSelectedSerialNumbers(oTrans, partNum, quantity,
whereClause, transType, sourceRowID, oTrans.adapter.CustShipData,
showAsModal), DataSet)
MessageBox.Show("DataSet")
If dataSet IsNot Nothing Then
oTrans.adapter.CustShipData.SNFormat.Clear()
oTrans.adapter.CustShipData.Merge(dataSet, False,
If (Dtl.dataView(Dtl.Row)("RowMod").ToString() <> "U") or
(Dtl.dataView(Dtl.Row)("RowMod").ToString() <> "A") Then
Dtl.dataView(Dtl.Row).BeginEdit()
Dtl.dataView(Dtl.Row)("RowMod") = "U"
Dtl.dataView(Dtl.Row).EndEdit()
End If
End If
End If
Catch Ex As Exception
MessageBox.Show(ex.ToString(),"Serial Number Select Error")
End try
Else
oTrans.Update()
Steve
just
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> On Tue, Aug 14, 2012 at 4:41 AM, spmyers7582 smyers@... wrote:
> > Hi Jose,
snsView. Is
to that
> > Thanks,
> > Steve
requirements,
custom
ofcourse
this.serialSearchAdapter.SerialNumberSearch(this.serialSearchAdapter.Ser\
this.snsView.dataView[0]["WhereClause"].ToString().Replace("<<PartNum>>"\
this.shipDtlView.dataView[this.shipDtlView.Row]["PartNum"].ToString()).R\
this.shipDtlView.dataView[this.shipDtlView.Row]["WarehouseCode"].ToStrin\
> > > int quantity =
int.Parse(this.shipDtlView.dataView[this.shipDtlView.Row]["DisplayInvQty\
"].ToString());
> > > if (quantity != 0)
> > > string partNum =
> > quantity,
> > > showAsModal);
> > > if
> > > "U") ||
> > > "A"))
> > > "U";
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > customisation
should be
> > in:
> > avail...
> > > > > Thanks
Seria N0?
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@
wrote:
> > > > > > > Hi,
> > automatic
with the
> > > > > > > following message:
> > > > > > > SNParams.Add(JobNo)
> > > > > > > SNParams.Add(Qty)
> > > > > > > Dim lfo As New
> > > > > > > Thanks for looking,
> > > > > > > Steve
In the code you pasted you havne't instantiated snView..
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Script:
> Try
> Dim SSNArgs As New
> End If
> End If
> End If
> End try
> Else
> oTrans.Update()
> Thanks,
> Steve
> just
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Hi Jose,
> snsView. Is
> to that
> > > Thanks,
> > > Steve
> requirements,
> custom
> ofcourse
> > > > int quantity =
> "].ToString());
> > > > if (quantity != 0)
> > > > string partNum =
> > > quantity,
> > > > showAsModal);
> > > > if
> > > > "U") ||
> > > > "A"))
> > > > "U";
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > customisation
> should be
> > > in:
> > > avail...
> > > > > > Thanks
> Seria N0?
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@
> wrote:
> > > > > > > > Hi,
> > > automatic
> with the
> > > > > > > > following message:
> > > > > > > > SNParams.Add(JobNo)
> > > > > > > > SNParams.Add(Qty)
> > > > > > > > Dim lfo As New
> > > > > > > > Thanks for looking,
> > > > > > > > Steve
This is declared above the code:
Imports
'// Add Custom Module Level Variables Here **
Dim SNSearchAD As New SerialNumberSearchAdapter(oTrans)
I assume this is not enough..
Steve
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Script:
> > Try
> > Dim SSNArgs As New
> > End If
> > End If
> > End If
> > End try
> > Else
> > oTrans.Update()
> > Thanks,
> > Steve
> > just
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > On Tue, Aug 14, 2012 at 4:41 AM, spmyers7582 smyers@ wrote:
> > > > Hi Jose,
> > snsView. Is
> > to that
> > > > Thanks,
> > > > Steve
> > requirements,
> > custom
> > ofcourse
> > > > > int quantity =
> > "].ToString());
> > > > > if (quantity != 0)
> > > > > string partNum =
> > > > quantity,
> > > > > showAsModal);
> > > > > if
> > > > > "U") ||
> > > > > "A"))
> > > > > "U";
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > > > customisation
> > should be
> > > > in:
> > > > avail...
> > > > > > > Thanks
> > Seria N0?
> > > > > > > > *Jose C Gomez*
> > > > > > > > *Software Engineer*
> > > > > > > > E: jose@
> > wrote:
> > > > > > > > > Hi,
> > > > automatic
> > with the
> > > > > > > > > following message:
> > > > > > > > > SNParams.Add(JobNo)
> > > > > > > > > SNParams.Add(Qty)
> > > > > > > > > Dim lfo As New
> > > > > > > > > Thanks for looking,
> > > > > > > > > Steve
*Jose C Gomez*
*Software Engineer*
E: jose@...
Steve
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
