I solved this. It helps it you save your changes before you test it.
Thanks to anyone who spent time in looking at this.
Mike
mike.numbers
Sent: Monday, July 01, 2013 3:19 PM
Subject: [Vantage] How do I link a table as Left Outer Join in a RDD
I have added Part to the Job Traveler RDD and linked it to JobAsmbl. I need
this to be Left Outer Join since we occasionally have "parts on the fly". In
the Report Data Maintenance option, on the Relationships tab, with List
screen, there is a column for Join Type. Originally it was blank. I changed
it to "Left Outer". I also changed the link option in the Crystal report to
Left Outer Joint and Not enforced. I must be missing something, because I
don't get any data when I run the report for a "part on the fly". I could
not find any documentation on the Report Data Maintenance option on what
values were valid in the Join Type. Any ideas on what I should try next?
9.04.507a
Mike
mike.numbers
9.04.507a
