Miguel A. Santillan
Compass Manufacturing Systems
Sent: Friday, July 24, 2015 7:12 PM
To: 'vantage@yahoogroups.com' <vantage@yahoogroups.com>
Subject: [Vantage] RE: How do I use the Criteria "Contains" in the BAQ
Thank you.
Sent: Friday, July 24, 2015 3:23 PM
use matches and set the constant to *DATA2* or *DATA3*
Greg
Sent: Friday, July 24, 2015 5:49 PM
Subject: [Vantage] How do I use the Criteria "Contains" in the BAQ
The UserFile has the Grouplist: DATA1~DATA2~DATA3~DATA4
I want to see records with only DATA2 or DATA3. I thought I could use the CONTAINS, but it doesn’t display anything. In the pop-up I did DATA2 | DATA 3
Miguel A. Santillan
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible
for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately
delete the communication.
"This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported
to foreign persons without prior approval form the U.S. Department of State."
