HI Epicor community, is there anyway to add in reason desc, nonconf tranID in the report? I’ve tried using report data definition but it won’t let me, appreciate your guys advise thanks
What error are you getting? Are you trying to change the standard Report data definition? You cannot change the standard data definition. You would need to duplicate the data definition to add/edit it and set that duplicated data definition in the report style.
The same for report style, you cannot edit the standard but require to copy the standard and make the duplications in the copy.
Hope it helps.
Hi @Mei_Mei_Tan , yeah I already duplicate it but it seems i got an error while adding the reason code in the miscpack report or I got it form the wrong table?
What kind of error? Can screenshot it?
I already revert back to the original report, I’ll try to replicate the error again
