How to add summary column on ultra grid
Anyone got the function in UltraWinGrid to programatically add a summary by column ? I would like to have the sum of amount ($) under each group.
Split into its own topic, please keep seach question on a separate topic so that they are easier to find later.
Sorry, didn’t want to create too many topics about the same thing.
I have this so far:
private void Expand_All_Rows_in_WinGrid_Load()
		myGrid = (EpiUltraGrid)csm.GetNativeControlReference("8dc6b497-02f3-4051-97c9-2299d46ab611");
		myGrid.DisplayLayout.ViewStyleBand = ViewStyleBand.OutlookGroupBy;
		myGrid.DisplayLayout.Bands[0].SortedColumns.Add("GLAccount_GLAccount", false, true);
		myGrid.DisplayLayout.Bands[0].Summaries.Add(SummaryType.Sum, myGrid.DisplayLayout.Bands[0].Columns["Calculated_Budget"]);
        myGrid.DisplayLayout.Override.SummaryDisplayArea = SummaryDisplayAreas.InGroupByRows | SummaryDisplayAreas.BottomFixed | SummaryDisplayAreas.RootRowsFootersOnly;
		myGrid.Rows.ExpandAll(true);
But it shows a grand total which is not what I want. I would like to programatically call the ‘Show Summaries’ function and then create a Sum Summary for my columns Calculated_Budget and Calculated_Amount
Edit: replaced my code with
myGrid = (EpiUltraGrid)csm.GetNativeControlReference(“8dc6b497-02f3-4051-97c9-2299d46ab611”);
myGrid.DisplayLayout.Bands[0].SortedColumns.Add(“GLAccount_GLAccount”, false, true);
myGrid.DisplayLayout.Bands[0].Summaries.Add(SummaryType.Sum, myGrid.DisplayLayout.Bands[0].Columns[“Calculated_Budget”]);
myGrid.DisplayLayout.Bands[0].Summaries.Add(SummaryType.Sum, myGrid.DisplayLayout.Bands[0].Columns[“Calculated_Amount”]);
myGrid.DisplayLayout.Override.AllowRowSummaries = AllowRowSummaries.Default;
It shows almost exactly like I want but it shows 2 lines of summaries…
I just had this same thing happen. It is because the function you put this code inside is being called more than once. I solved it with a simple boolean flag like this:
	private void edvV_ReadyToShip_2_1View_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
EpiUltraGrid myGrid = (EpiUltraGrid)csm.GetNativeControlReference("0c4673fe-dec2-407d-954e-6d60cdd7b850");
		if (init == false)
myGrid.DisplayLayout.Bands[0].Columns["Calculated_ShipAmt"]);
init = true;
		ExpandRows(myGrid.Rows);
I initialized init as a false boolean up in the public class script. Thanks for sharing your code, it helped me out!
