How to block popup with BPM?
We do not use Qty Price Breaks, the setting “Generate Quantities From Price Breaks” is disabled under Company Config - Modules - Sales - Quote. Every time a new quote line is added and the Product Group is changed, we get the popup “Do you want to refresh the break quantities? Yes/No”. Our sale people would like to eliminate this popup. Opened a ticket with Epicor and they say there is no setting to disable it, but it can be done with a BPM.
Ok, how do I do this with a BPM? I have tried setting the field in a post-processing directive of ChangeProdCode and also tried setting the refreshQty parameter of GetPriceListInfo in a pre-processing directive. Neither has any effect on the popup.
So I assume that ChangeProdCode and GetPriceListInfo are the only methods called and in that order?
Have you used the Trace Log Helper from @josecgomez (et al) to verify there aren’t any other fields needing to be set?
I think refreshQty would need to be set post processing and the message prompt may also need to be set to blank.
