How to Calculate Standard Labor Hours Embedded in Assemblies Sold (Sales-Based, BOM-Exploded)?
Hello,
I’m trying to determine the total standard labor hours embedded in parts sold during 2025.
I can run the Sales Gross Margin report for specific product groups and it provides a cost breakdown for labor, burden, material, and outside processing. However, when the sold item is an assembly, the labor from lower-level parts and subassemblies is rolled up and presented as material cost, so the true standard labor hours are not visible.
I also attempted to use the BOM Cost Report to explode the assemblies and capture standard labor, but the report does not complete when exporting to CSV—either when running multiple product codes together or individually.
My goal is to calculate:
Shipped quantity × standard labor hours from the full BOM/routing (including subassemblies)
If you want labor broken out like that you need to utilize the “Enable Mfg Cost Elements” so that it gets broken out like that through the process.
See the job costing technical reference guide for more info.
The BOM cost report, however, doesn’t acknowledge the enable MFG cost elements logic and is always kept in separate buckets like you just said.
Do you know how to create your own report style? You could create a tablix out of the data that fits what you are looking for maybe?
Are you referring a Custom BAQ report ?
Nah, I’m referring to customizing an out-of-the-box report.
You can copy the report style and do whatever you want to the report, so if you want the data from the BOM cost report in a table format, just take the data and put it into the table like you want it so that when you export it, it is in the format you need.
So, no need to enable the enable MFG cost element in the company configuration, correct?
Don’t quote me, but doesn’t the BOM cost report already do this? It already breaks out the costs like you want, right? If so, then yeah you don’t need to touch anything at the company config level. However, if accounting is looking to report the costs like that on the GL you may wish to look into this setting.
I recently made a BAQ that summarizes burden hours by resource group for each customer (could be by part also). There are some assumptions that must be made if your MFG parts are made for stock like ours are. I chose to calculate the average resource hours per closed job over the time frame and multiply that by the parts sold. If this sounds useful, I can share any details you would find useful.
Yes, I require information for the last year alone which we sold. standard BOM Cost report shows as on date.
FFT_machinehourbyresourcepart.baq (196.3 KB)
Certainly, the attached should be easy to modify for your needs if you would like to use actual jobs hour averages. You would need to change the machine hour logic to labor hour logic in the jobs subquery. This could be said to be better than standard since it includes job quantity variance for setup time…
Nice Mike. I will look at this.
