Your best bet is gonna be to publish the dashboard and then use a
customization which will give you access to each Grid's data view directly.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Tue, May 7, 2013 at 8:39 AM, brenda mohr <brenda@...> wrote:
> I have a dashboard in which I am attempting to customize a tracker view.
> The dashboard has four separate sections, each has their own Grid View and
> Tracker on it and is driven from 4 separate BAQ's.
> The top left Grid View has a list of all Quote Numbers with Customer Name
> and Customer ID. As a user selects a record in that Grid View, I have a
> button in a separate dashboard tracker section (bottom right). If a record
> is selected in the upper left section and the user pushes the button in the
> lower right section, I would like the Quote Number, Customer Name, and ID
> to appear in the text of the message box message.
> Before, the values were published and we were using the following code:
> DBTVP.GetCurrentPublishedValue("BDS-QuoteOpenPortal- 10-QuoteOpenPortal:
> QuoteHed.QuoteNum");
> But am receiving the following error:
> Error: CS0117 - line 87 (119) - 'object' does not contain a definition for
> 'GetCurrentPublishedValue'
> My question is, what is the correct way to call data from a grid view that
> is different from the data the tracker is looking at? Is attempting to read
> the published values the best route? If so, does anyone know the correct
> syntax? Or is there another way to access the grid view data?
> Brenda (For 9.05.701)
> (Also Posted on the Epicor Group)
