How to catch "Save" event in V8 vb.net
when you write code like this, how to you setup/use it in vantage?
Of Stephen Edginton
Sent: Wednesday, November 01, 2006 5:26 PM
Subject: RE: [Vantage] how to catch "Save" event in V8 vb.net
Joe,
Sorry I did not actually test that last code. Note sure
exactly what you are trying to do but, You can always use the following
(this detects changes made to the CommentText in DMR head.
Private Sub DMRHead_BeforeFieldChange(ByVal sender As object, ByVal args
As DataColumnChangeEventArgs) Handles DMRHead_Column.ColumnChanging
'// ** Argument Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Select Case args.Column.ColumnName
Case "CommentText"
MessageBox.Show("Comment Text
changed ")
Case Else
End Select
End Sub
Regards,
Stephen Edginton
Behalf
Of Jose Ferrer
Sent: 01 November 2006 22:59
Unfortunately, in this particulary screen ("DMRProcessing"), this option
did
not work, it is doing other type of call
In Vantage when the screen have "special" views (like virtual view)
sometimes this code do not work another example of this special views is
the
Inventory Transfer screen where ther is not a direct relationship
between
the view and the data tables
Regards,
Jose Ferrer
>From: "Stephen Edginton" <stephene@...
<mailto:stephene%40dotnetit.co.uk>
<mailto:stephene%40dotnetit.co.uk> >
>Reply-To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
>To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> >
>Date: Wed, 1 Nov 2006 22:22:26 -0000
>Jose,
> Take a look at the FormEventWizard -> BeforeAdapterMethod for
>the adapter
>Private Sub oTrans_adapter_BeforeAdapterMethod(ByVal sender As object,
>ByVal args As BeforeAdapterMethodArgs) Handles
>oTrans_adapter.BeforeAdapterMethod
> '// args.MethodName, args.Cancel
> Select Case args.MethodName
> Case "Update"
> 'Do checking here
> 'Dim dRes As DialogResult =
>MessageBox.Show("Cancel Update?", "Cancel", MessageBoxButtons.YesNo)
> 'If (dRes = DialogResult.Yes) Then
> 'args.Cancel = True
> 'Else
> ' 'Do Something Else
> 'End If
> Case Else
> End Select
>End Sub
>Regards,
>Stephen Edginton
>-----Original Message-----
Behalf
>Of Jose Ferrer
>Sent: 01 November 2006 21:56
>Thank you, good tip but unfortunately we have 8.00.809g and I agree,
>there
>are some screens that are not using the standard "Save" method call
>Regards,
>Jose Ferrer
> > >From: "ferrerspine" <ferrerj@...
<mailto:ferrerj%40hotmail.com>
<mailto:ferrerj%40hotmail.com> >
> > >Subject: [Vantage] how to catch "Save" event in V8 vb.net
> > >Date: Wed, 01 Nov 2006 20:01:55 -0000
> > >Hello
> > >Is there a way to catch the "Save" event when a user click the
"save"
> > >button in the tool bar?
> > >we are using V8-vb.net
> > >This because in form DMR processing the standard way to apply
> > >validation before save does not work, I need to add some
validations
> > >when the user save the data
> > >Thanks for your help,
> > >Jose Ferrer
__________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
<http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/>
<http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/> >
Hello
Is there a way to catch the "Save" event when a user click the "save"
validation before save does not work, I need to add some validations
Jose Ferrer
If you have 8.03, you can use the new BMP module to insert code (validation
code) at the before, base, or after stream of the save function. Seems to
work well (from looking at it during Perspectives). It basically sits
between the UI layer and the db committment layer. I am going to do it to
auto-hold sales orders when the GETNEW() function is called from the SO UI.
However, the underlying code in the GETNEW() and SAVE() SEEMS to be a little
different depending on which logicial module you are using. So, you would
likely have to do this for each place you want to intercept the save
command.
Carey
>From: "ferrerspine" <ferrerj@...>
>Hello
>Jose Ferrer
_________________________________________________________________
Find a local pizza place, music store, museum and more�then map the best
route! http://local.live.com?FORM=MGA001
Thank you, good tip but unfortunately we have 8.00.809g and I agree, there
Regards,
Jose Ferrer
>From: "Carey S" <rotary1@...>
>Date: Wed, 01 Nov 2006 15:35:56 -0600
>little
>command.
>Carey
> >Hello
> >Jose Ferrer
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
>already linked your email address to a yahoo id to enable access. )
>(1) To access the Files Section of our Yahoo!Group for Report Builder and
>Crystal Reports and other 'goodies', please goto:
>http://groups.yahoo.com/group/vantage/files/.
>(2) To search through old msg's goto:
>http://groups.yahoo.com/group/vantage/messages
>(3) To view links to Vendors that provide Vantage services goto:
>http://groups.yahoo.com/group/vantage/links
>Yahoo! Groups Links
Don't just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
Jose,
the adapter
Case "Update"
'Do checking here
'args.Cancel = True
'Else
'End If
Case Else
End Select
End Sub
Regards,
Stephen Edginton
Of Jose Ferrer
there
Regards,
Jose Ferrer
> >Hello
> >Jose Ferrer
Unfortunately, in this particulary screen ("DMRProcessing"), this option did
sometimes this code do not work another example of this special views is the
Inventory Transfer screen where ther is not a direct relationship between
Regards,
Jose Ferrer
>From: "Stephen Edginton" <stephene@...>
>To: <vantage@yahoogroups.com>
>Jose,
>the adapter
> Case "Update"
> 'Do checking here
> 'args.Cancel = True
> 'Else
> 'End If
> Case Else
> End Select
>End Sub
>Regards,
>Stephen Edginton
>Of Jose Ferrer
>there
>Regards,
>Jose Ferrer
> > >Hello
> > >Jose Ferrer
Joe,
Case "CommentText"
changed ")
Case Else
End Select
End Sub
Regards,
Stephen Edginton
Of Jose Ferrer
did
the
between
Regards,
Jose Ferrer
>To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
>Jose,
>the adapter
> Case "Update"
> 'Do checking here
> 'args.Cancel = True
> 'Else
> 'End If
> Case Else
> End Select
>End Sub
>Regards,
>Stephen Edginton
Behalf
>Of Jose Ferrer
>there
>Regards,
>Jose Ferrer
> > >Hello
"save"
validations
> > >Jose Ferrer
