How to change license codes Vantage 803
That did the trick, cheers!
Now to set up BPM...
Jonathan
--- In vantage@yahoogroups.com, "vantage803" <bash100@...> wrote:
> Jonathan;
> In your Admin Tools, go to your 2nd selection
> "Configure Company" and select this
> In the list you will see a list of your Company/ies
> Double click the first one, this will open up with a window to
allow
> you to configure a specific license per company.
> Select the search tool to pick the license you desire, note the s/n
> that you want to use.
> Continue down with the remaining companies and you should be good
to
> go
> -Joe
> > Hi All,
> > Received an email from Epicor with my new 803 codes including BPM.
> > I tried going to the 'configure license' screen in Admin Tools
and
> > add BPM using the code supplied. This came up with an invalid
code
> > error then I realised that the Serial number at the top of my new
> > codes was different to what I had on the screen.
> > I entered the new serial number and associated codes (inc BPM) to
> the
> > license screen and OK'd it.
> > Now I've got 2 different lists of licenses installed, defaulting
to
> > the one without BPM. On trying to delete the old one, it says a
> > company is still using it!
> > How do I set these new codes to be the default and/or delete the
> old
> > serial number and it's associated codes?
> > (Apologies for length)
> > Jonathan
Hi All,
I tried going to the 'configure license' screen in Admin Tools and
add BPM using the code supplied. This came up with an invalid code
I entered the new serial number and associated codes (inc BPM) to the
Now I've got 2 different lists of licenses installed, defaulting to
How do I set these new codes to be the default and/or delete the old
Jonathan
Jonathan;
Double click the first one, this will open up with a window to allow
Continue down with the remaining companies and you should be good to
go
-Joe
> Hi All,
the
old
> Jonathan
