Presumably your subcontract OP is back-flush (to match subcontract PO qty rcv'd).
If you are set up to adjust job qty based upon OP yield, receiving the PO as complete (although short) should have closed the OP out and reduced your job qty to 49.
If you aren't using yield recalc, reduce job qty to 49.
Question: Did you send the vendor 50 and only receive 49 (scrap loss of 1)?
If so, you should receive 50 from the PO and scrap one in the inspection process.
Rob Brown
Rob Brown
--- On Fri, 8/15/08, kimakunze <kkunze@...> wrote:
Subject: [Vantage] How to complete a subcontract PO short
Date: Friday, August 15, 2008, 4:53 PM
Hello group, I need to tap into your wisdom. Our version 8.03.404
We have a job to produce 50 parts and the method is simple: pull
inventory from stock, send it to our subcontractor for value added
work and receive the completed parts back into inventory. The
subcontract PO is received complete for one less than we ordered and
complete the receipt for 49. Last operation in the method is to put
them away in our stock room and labor qty reported 49 complete.
I don't plan to send one more part to the subcontractor.
I don't have a min set on the part but I have a min lot size of 50.
But I'm getting a new PO suggestion for subcontracting for the
original job for another 50, I'm guessing because I received the
original subcontract PO one short of the order? The subcontract op
does not show complete either.
I an looking for a way to make this suggestion go away.
This isn't an unusual situation for us and I'm hoping not for some of
you as well. Anyone have a solution of some kind?
Thanks for considering this.
