How to construct a where clause in web service proxy for Vantag
Thanks Stephen,
This is extactly what I want!
Is this syntax is part of Progress query syntax?
--Charlie
--- In vantage@yahoogroups.com, "Stephen Edginton" <stephene@...>
wrote:
> How about MATCHES *west*
Behalf
> Of bw2868bond
> Sent: 04 September 2007 20:07
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: How to construct a where clause in web
service
> proxy for Vantage 8.0.3 ?
> AFAIK you can only use CONTAINS on fields that have a Word Index
> associated with them.
> You could create a WordIndex on the name field or you can return
the
> entire customer dataset and then use a .net string method to return
> names that have the desired search term in them...
> bw
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "cminglu" <cminglu@> wrote:
> > Hi, All,
> > I am new to this forum, I am trying to build a mobile solution
> (i.e.
> > web portal to access the Vantage Service 8.0.3 via web service
> adapter
> > calls).
> > I am trying to query a list of customers by using the following
> code:
> > returnVal = CustomerSearch.ExecuteMethod("GetList", new object
> > whereClause, pageSize, absolutePage });
> > What is the correct way to construct the whereClause?
> > For example, I want to get a list of customers who's company name
> > contains 'West'.
> > (1) where Company = 'VN10T' and (Name Begins 'West') -- works
> only
> > for customers whose name starts with 'West'.
> > (2) where Company = 'VN10T' and (Name CONTAINS 'West') -- does
> not
> > work, with invalid query for the webservice error.
> > (3) where Company = 'VN10T' and Name like '%West%' -- SQL like
> query
> > does not work either.
> > Does this whereClause uses the Progress query syntax? Anybody has
> > examples that can share?
> > Thanks in advance.
> > --Charlie.
Hi, All,
I am new to this forum, I am trying to build a mobile solution (i.e.
web portal to access the Vantage Service 8.0.3 via web service adapter
calls).
I am trying to query a list of customers by using the following code:
returnVal = CustomerSearch.ExecuteMethod("GetList", new object[] {
contains 'West'.
(1) where Company = 'VN10T' and (Name Begins 'West') -- works only
(2) where Company = 'VN10T' and (Name CONTAINS 'West') -- does not
(3) where Company = 'VN10T' and Name like '%West%' -- SQL like query
Thanks in advance.
--Charlie.
You could create a WordIndex on the name field or you can return the
bw
--- In vantage@yahoogroups.com, "cminglu" <cminglu@...> wrote:
> Hi, All,
(i.e.
adapter
> calls).
code:
> contains 'West'.
only
not
query
> Thanks in advance.
> --Charlie.
Of bw2868bond
Subject: [Vantage] Re: How to construct a where clause in web service
bw
> Hi, All,
(i.e.
adapter
> calls).
code:
> contains 'West'.
only
not
query
> Thanks in advance.
> --Charlie.
