How to create a method process
As we all know, each module has its own stack of method processes GetNew, ChangePart, GetID, ChangeRev, etc.
As for a UD table, they only come with a small 8 or so method processes. I looked through the site for an answer and could not find. Is there a way to create/add a method/process. Im looking to trigger a process after tabbing out of a field after entering data. Similar to other modules when you tab out of the partnum the description automatically fills in.
Thank you for your guidance.
That is where you would use a Customization or App Studio. If you need really fancy work done, call a Function from the event.
