How To Create a Sales Order Detail Record in Code?
Glad I could help.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Thu, Feb 24, 2011 at 9:18 AM, zanniebelle <rwatson@...> wrote:
> This Worked!!!
> _edvOrderDtl.Notify(new EpiNotifyArgs(oTrans,0,_edvOrderDtl.Column));
> This didn't:
> EpiNotifyArgs(oTrans,edvOrderDtl.Row,_edvOrderDtl.Column));
> Thank You!!
Hi,
Has anyone created a sales order detail line in a customization?
I can create the detail record using SalesOrderAdapter.GetNewOrderDtl(OrderNum), but I can't figure out how to set the fields in the new record.
I tried using the OrderDtl view, but as soon as I set it's row to 0 (the new detail record) an error occurs as though it tries to update the detail record and the PartNum field not been set.
I tried SalesOrderAdapter.GetPartXRefInfo thinking it would populate the PartNum field, but that doesn't work.
I also tried using SalesOrderAdapter.SalesOrderData.OrderDtl.Rows[0] to access the field and it errors out with index is out of range.
If anyone has an example It would greatly appreciate it.
Ray
As long as your are instantiating your adapter correctly the second option
should work fine. Can you post the code you are using to instantiate the
adapter and such?
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Feb 23, 2011 at 4:12 PM, zanniebelle <rwatson@...> wrote:
> Hi,
> Thanks,
> Ray
Hi Jose,
You have helped me in the past, thanks for replying. I'm not at work right now so I'll try this from memory:
The salesorderadapter is instantiated as follows:
SalesOrderAdapter _salesOrderAdpter = (SalesOrderAdapter) oTrans.PrimaryAdapter;
I then create a header record with it, and I call _salesOrderAdapter.Update() so that I can get the new OrderNum.
I use the OrderNum to get a new detail record:
_salesOrderAdapter.GetNewOrderDtl(OrderNum)
All this works fine, so I think my SalesOrderAdapter is correctly instantiated.
I try to access the fields like this:
_salesOrderAdapter.SalesOrderData.OrderDtl.Rows[0]["PartNum"]="AdditionalCharges";
This where it throws an index out of range error.
I also tried using a EpiDataView:
_edvOrderDtl.dataView[0]["PartNum"]="AdditionalCharges";
It also throws the index out of range error.
One last thing that's strange, if I try to set the EpiDataView Row property, i.e. _edvOrderDtl.Row=0, I think it trys to do an Update, because I get a core/bo/SalesOrder error that states PartNum and PartDesc cannot be empty.
By the way, I do almost identical code to create a PO in code with no problems???
I'll post the exact code in the morning...
Thanks again!
Ray
> adapter and such?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi,
> > Thanks,
> > Ray
Are you created the Head in code also? Have you tried doing the creating by
hand doing a Trace? We create a lot of Orders in code and I am not at work
either right now, but I believe you may need to call another BO in
between... I'll confirm in the morning.
Are you doing this Within Order Entry???
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Feb 23, 2011 at 6:59 PM, zanniebelle <rwatson@...> wrote:
> Hi Jose,
> instantiated.
> empty.
> problems???
> Thanks again!
> Ray
> option
> > adapter and such?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Hi,
> to
> (the
> detail
> the
> > > Thanks,
> > > Ray
The Order is created by the user. Once they click save I capture the
update in the oTrans_ordAdapter_AfterAdapterMethod method. I want the
detail line I'm creating to be the first line on the order so I check to
see if there are any lines and call the below method if there are no
lines.
I did do a trace when the order and detail line are created manually and
it is included at the end of this posting.
Notes: _salesOrderAdapter and _edvOrderDtlis are member vars that are
used throughout the code. They are intstantiated in the method
InitializeCustomCode as follow:
_salesOrderAdapter = (SalesOrderAdapter) oTrans.PrimaryAdapter;
_edvOrderDtl = (EpiDataView) (oTrans.EpiDataViews["OrderDtl"]);
Thanks for your help,
Ray
private static void CreateSODetailLineWMiscRecs()
try
int li_orderNum;
string ls_partnum;
string ls_uom="";
string ls_serialWarning;
string ls_questionString;
string ls_msg="";
string ls_msg2 = "";
string ls_msgType;
bool lbln_multipleMatch;
bool lbln_isAvail;
li_orderNum = (int)
_salesOrderAdapter.SalesOrderData.OrderHed.Rows[0]["OrderNum"];
EpiDataView lo_hedView = (EpiDataView)
oTrans.EpiDataViews["OrderHed"];
// get new order detail record
EpiMessageBox.Show("Calling GetNewOrderDtl, OrderNum:" +
li_orderNum.ToString());
if (_salesOrderAdapter.GetNewOrderDtl(li_orderNum))
// get part xref info
EpiMessageBox.Show("GetPartXRefInfo\n");
ls_partnum = "AdditionalCharges";
_salesOrderAdapter.GetPartXRefInfo(ref ls_partnum,"","",ref ls_uom,
out ls_serialWarning,out ls_questionString,out lbln_multipleMatch);
// check part revision change
EpiMessageBox.Show("CheckPartRevisionChange\n");
_salesOrderAdapter.CheckPartRevisionChange(li_orderNum,0,"PartNum",ref
ls_partnum,
out ls_msg,out ls_msg2,out lbln_isAvail,out ls_msgType);
// change part number
EpiMessageBox.Show("ChangePartNum\n");
_salesOrderAdapter.ChangePartNum(false,ls_uom);
// change selling quantity
EpiMessageBox.Show("ChangeSellingQuantity\n");
_salesOrderAdapter.ChangeSellingQuantity(false,(decimal)1.00, out
ls_msg);
try
// this causes an update to fire, which results in a core error
that the
// displays 1. No Header Changes 2. PartNum and PartDesc are empty
EpiMessageBox.Show("Setting _edvOrderDtl.Row=0\n");
_edvOrderDtl.Row=0;
catch (Exception ex)
EpiMessageBox.Show("Error: _edvOrderDtl.Row=0...\n" +
ex.ToString());
// set the required fields
EpiMessageBox.Show("Setting Row defaults\nRow Count:" +
_salesOrderAdapter.SalesOrderData.OrderDtl.Rows.Count);
// this causes an IndexOutOfRangeException
_salesOrderAdapter.SalesOrderData.OrderDtl.Rows[0]["PartNum"] =
ls_partnum;
EpiMessageBox.Show("Made it here");
_salesOrderAdapter.SalesOrderData.OrderDtl.Rows[0]["ProdCode"]="Other";
_salesOrderAdapter.SalesOrderData.OrderDtl.Rows[0]["OrderQty"]=
(decimal)1.00;
_salesOrderAdapter.SalesOrderData.OrderDtl.Rows[0]["ProjectId"]=
lo_hedView.dataView[0]["ShortChar01"];
_salesOrderAdapter.SalesOrderData.OrderDtl.Rows[0]["ShortChar01"]=
"0";
_salesOrderAdapter.SalesOrderData.OrderDtl.Rows[0]["TaxCatID"]=
"S0000000";
// update
EpiMessageBox.Show("B4 Update");
_salesOrderAdapter.Update();
//EpiMessageBox.Show("Created new part detail record, " +
_salesOrderAdapter.SalesOrderData.OrderDtl.Rows[0]["OrderLine"].ToString\
// for each _miscDataAdapter rows create a orderline misc record
// GetNewOrderMsc(orderNum,orderline)
// update
// screen refresh
_salesOrderAdapter.GetByID(li_orderNum);
EpiMessageBox.Show(ex.ToString());
**************** Trace
<tracePacket>
<businessObject>Epicor.Mfg.BO.SalesOrder</businessObject>
<methodName>GetNewOrderDtl</methodName>
<returnType>void</returnType>
<localTime>02/23/2011 15:53:05:2845743 PM</localTime>
<executionTime>343.7456</executionTime>
<parameters>
<parameter name='ds' type='Epicor.Mfg.BO.SalesOrderDataSet'
><SalesOrderDataSet
xmlns="http://www.epicor.com/Mfg/100/BO.SalesOrder/SalesOrder
<http://www.epicor.com/Mfg/100/BO.SalesOrder/SalesOrder> "
/></parameter>
<parameter name='orderNum' type='System.Int32'
><![CDATA[100122]]></parameter>
</parameters>
<paramDataSetChanges>
</paramDataSetChanges>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.BO.XDocTypeCtrl</businessObject>
<methodName>GetList</methodName>
<returnType>Epicor.Mfg.BO.XDocTypeCtrlListDataSet</returnType>
<localTime>02/23/2011 15:53:08:2220367 PM</localTime>
<executionTime>46.8744</executionTime>
<parameters>
<parameter name='whereClause' type='System.String' ><![CDATA[TableName
= 'OrderHed' BY TableName]]></parameter>
<parameter name='pageSize' type='System.Int32'
><![CDATA[0]]></parameter>
<parameter name='absolutePage' type='System.Int32'
<parameter name='morePages' type='System.Boolean'
><![CDATA[]]></parameter>
</parameters>
</tracePacket>
<tracePacket>
<methodName>GetPartXRefInfo</methodName>
<localTime>02/23/2011 15:53:17:9562871 PM</localTime>
<executionTime>140.6232</executionTime>
<parameters>
<parameter name='partNum' type='System.String'
><![CDATA[AdditionalCharges]]></parameter>
<parameter name='sysRowID' type='System.String'
<parameter name='rowType' type='System.String'
<parameter name='uomCode' type='System.String'
<parameter name='serialWarning' type='System.String'
<parameter name='questionString' type='System.String'
<parameter name='multipleMatch' type='System.Boolean'
</parameters>
</tracePacket>
<tracePacket>
<methodName>CheckPartRevisionChange</methodName>
<localTime>02/23/2011 15:53:20:4250055 PM</localTime>
<executionTime>124.9984</executionTime>
<parameters>
<parameter name='iOrderNum' type='System.Int32'
<parameter name='iOrderLine' type='System.Int32'
<parameter name='cFieldName' type='System.String'
><![CDATA[PartNum]]></parameter>
<parameter name='cPartNum' type='System.String'
<parameter name='cConfigPartMessage' type='System.String'
<parameter name='cSubPartMessage' type='System.String'
<parameter name='lSubAvail' type='System.Boolean'
<parameter name='cMsgType' type='System.String'
</parameters>
</tracePacket>
<tracePacket>
<methodName>ChangePartNum</methodName>
<localTime>02/23/2011 15:53:20:5656287 PM</localTime>
<executionTime>531.2432</executionTime>
<parameters>
><SalesOrderDataSet
/></parameter>
<parameter name='lSubstitutePartsExist' type='System.Boolean'
><![CDATA[False]]></parameter>
</parameters>
<paramDataSet name='ds' useDataSetNbr='0' >
<changedValue tableName='OrderDtl' rowState='Added' rowNum='0'
colName='VoidLine' ><![CDATA[False]]></changedValue>
colName='OpenLine' ><![CDATA[True]]></changedValue>
colName='Company' ><![CDATA[AGI]]></changedValue>
colName='OrderNum' ><![CDATA[100122]]></changedValue>
colName='OrderLine' ><![CDATA[0]]></changedValue>
colName='LineType' ><![CDATA[PART]]></changedValue>
colName='PartNum' ><![CDATA[AdditionalCharges]]></changedValue>
colName='LineDesc' ><![CDATA[]]></changedValue>
colName='Reference' ><![CDATA[]]></changedValue>
colName='IUM' ><![CDATA[EA]]></changedValue>
colName='RevisionNum' ><![CDATA[]]></changedValue>
colName='POLine' ><![CDATA[]]></changedValue>
colName='Commissionable' ><![CDATA[True]]></changedValue>
colName='DiscountPercent' ><![CDATA[0]]></changedValue>
colName='UnitPrice' ><![CDATA[0]]></changedValue>
colName='DocUnitPrice' ><![CDATA[0]]></changedValue>
colName='OrderQty' ><![CDATA[0]]></changedValue>
colName='Discount' ><![CDATA[0]]></changedValue>
colName='DocDiscount' ><![CDATA[0]]></changedValue>
colName='RequestDate' ><![CDATA[02/16/2011 00:00:00]]></changedValue>
colName='ProdCode' ><![CDATA[]]></changedValue>
colName='XPartNum' ><![CDATA[]]></changedValue>
colName='XRevisionNum' ><![CDATA[]]></changedValue>
colName='PricePerCode' ><![CDATA[]]></changedValue>
colName='OrderComment' ><![CDATA[]]></changedValue>
colName='ShipComment' ><![CDATA[]]></changedValue>
colName='InvoiceComment' ><![CDATA[]]></changedValue>
colName='PickListComment' ><![CDATA[]]></changedValue>
colName='TaxCatID' ><![CDATA[]]></changedValue>
colName='AdvanceBillBal' ><![CDATA[0]]></changedValue>
colName='DocAdvanceBillBal' ><![CDATA[0]]></changedValue>
colName='QuoteNum' ><![CDATA[0]]></changedValue>
colName='QuoteLine' ><![CDATA[0]]></changedValue>
colName='TMBilling' ><![CDATA[False]]></changedValue>
colName='OrigWhyNoTax' ><![CDATA[]]></changedValue>
colName='NeedByDate' ><![CDATA[02/10/2011 00:00:00]]></changedValue>
colName='CustNum' ><![CDATA[327]]></changedValue>
colName='Rework' ><![CDATA[False]]></changedValue>
colName='RMANum' ><![CDATA[0]]></changedValue>
colName='RMALine' ><![CDATA[0]]></changedValue>
colName='Character01' ><![CDATA[]]></changedValue>
colName='Character02' ><![CDATA[]]></changedValue>
colName='Character03' ><![CDATA[]]></changedValue>
colName='Character04' ><![CDATA[]]></changedValue>
colName='Character05' ><![CDATA[]]></changedValue>
colName='Character06' ><![CDATA[]]></changedValue>
colName='Character07' ><![CDATA[]]></changedValue>
colName='Character08' ><![CDATA[]]></changedValue>
colName='Character09' ><![CDATA[]]></changedValue>
colName='Character10' ><![CDATA[]]></changedValue>
colName='Number01' ><![CDATA[0]]></changedValue>
colName='Number02' ><![CDATA[0]]></changedValue>
colName='Number03' ><![CDATA[0]]></changedValue>
colName='Number04' ><![CDATA[0]]></changedValue>
colName='Number05' ><![CDATA[0]]></changedValue>
colName='Number06' ><![CDATA[0]]></changedValue>
colName='Number07' ><![CDATA[0]]></changedValue>
colName='Number08' ><![CDATA[0]]></changedValue>
colName='Number09' ><![CDATA[0]]></changedValue>
colName='Number10' ><![CDATA[0]]></changedValue>
colName='Date01' ><![CDATA[]]></changedValue>
colName='Date02' ><![CDATA[]]></changedValue>
colName='Date03' ><![CDATA[]]></changedValue>
colName='Date04' ><![CDATA[]]></changedValue>
colName='Date05' ><![CDATA[]]></changedValue>
colName='CheckBox01' ><![CDATA[False]]></changedValue>
colName='CheckBox02' ><![CDATA[False]]></changedValue>
colName='CheckBox03' ><![CDATA[False]]></changedValue>
colName='CheckBox04' ><![CDATA[False]]></changedValue>
colName='CheckBox05' ><![CDATA[False]]></changedValue>
colName='ProjectID' ><![CDATA[]]></changedValue>
colName='ContractNum' ><![CDATA[0]]></changedValue>
colName='ContractCode' ><![CDATA[]]></changedValue>
colName='BasePartNum' ><![CDATA[]]></changedValue>
colName='Warranty' ><![CDATA[False]]></changedValue>
colName='WarrantyCode' ><![CDATA[]]></changedValue>
colName='MaterialDuration' ><![CDATA[0]]></changedValue>
colName='LaborDuration' ><![CDATA[0]]></changedValue>
colName='MiscDuration' ><![CDATA[0]]></changedValue>
colName='MaterialMod' ><![CDATA[]]></changedValue>
colName='LaborMod' ><![CDATA[]]></changedValue>
colName='WarrantyComment' ><![CDATA[]]></changedValue>
colName='Onsite' ><![CDATA[False]]></changedValue>
colName='MatCovered' ><![CDATA[False]]></changedValue>
colName='LabCovered' ><![CDATA[False]]></changedValue>
colName='MiscCovered' ><![CDATA[False]]></changedValue>
colName='SalesUM' ><![CDATA[EA]]></changedValue>
colName='SellingFactor' ><![CDATA[1]]></changedValue>
colName='SellingQuantity' ><![CDATA[0]]></changedValue>
colName='SalesCatID' ><![CDATA[ML]]></changedValue>
colName='ShipLineComplete' ><![CDATA[False]]></changedValue>
colName='CumeQty' ><![CDATA[0]]></changedValue>
colName='CumeDate' ><![CDATA[]]></changedValue>
colName='MktgCampaignID' ><![CDATA[Base]]></changedValue>
colName='MktgEvntSeq' ><![CDATA[1]]></changedValue>
colName='LockQty' ><![CDATA[False]]></changedValue>
colName='Linked' ><![CDATA[False]]></changedValue>
colName='ICPONum' ><![CDATA[0]]></changedValue>
colName='ICPOLine' ><![CDATA[0]]></changedValue>
colName='ExtCompany' ><![CDATA[]]></changedValue>
colName='LastConfigDate' ><![CDATA[]]></changedValue>
colName='LastConfigTime' ><![CDATA[0]]></changedValue>
colName='LastConfigUserID' ><![CDATA[]]></changedValue>
colName='ConfigUnitPrice' ><![CDATA[0]]></changedValue>
colName='ConfigBaseUnitPrice' ><![CDATA[0]]></changedValue>
colName='PriceListCode' ><![CDATA[]]></changedValue>
colName='BreakListCode' ><![CDATA[]]></changedValue>
colName='PricingQty' ><![CDATA[0]]></changedValue>
colName='LockPrice' ><![CDATA[False]]></changedValue>
colName='ListPrice' ><![CDATA[0]]></changedValue>
colName='DocListPrice' ><![CDATA[0]]></changedValue>
colName='OrdBasedPrice' ><![CDATA[0]]></changedValue>
colName='DocOrdBasedPrice' ><![CDATA[0]]></changedValue>
colName='PriceGroupCode' ><![CDATA[]]></changedValue>
colName='OverridePriceList' ><![CDATA[False]]></changedValue>
colName='BaseRevisionNum' ><![CDATA[]]></changedValue>
colName='PricingValue' ><![CDATA[0]]></changedValue>
colName='Number11' ><![CDATA[0]]></changedValue>
colName='Number12' ><![CDATA[0]]></changedValue>
colName='Number13' ><![CDATA[0]]></changedValue>
colName='Number14' ><![CDATA[0]]></changedValue>
colName='Number15' ><![CDATA[0]]></changedValue>
colName='Number16' ><![CDATA[0]]></changedValue>
colName='Number17' ><![CDATA[0]]></changedValue>
colName='Number18' ><![CDATA[0]]></changedValue>
colName='Number19' ><![CDATA[0]]></changedValue>
colName='Number20' ><![CDATA[0]]></changedValue>
colName='Date06' ><![CDATA[]]></changedValue>
colName='Date07' ><![CDATA[]]></changedValue>
colName='Date08' ><![CDATA[]]></changedValue>
colName='Date09' ><![CDATA[]]></changedValue>
colName='Date10' ><![CDATA[]]></changedValue>
colName='Date11' ><![CDATA[]]></changedValue>
colName='Date12' ><![CDATA[]]></changedValue>
colName='Date13' ><![CDATA[]]></changedValue>
colName='Date14' ><![CDATA[]]></changedValue>
colName='Date15' ><![CDATA[]]></changedValue>
colName='Date16' ><![CDATA[]]></changedValue>
colName='Date17' ><![CDATA[]]></changedValue>
colName='Date18' ><![CDATA[]]></changedValue>
colName='Date19' ><![CDATA[]]></changedValue>
colName='Date20' ><![CDATA[]]></changedValue>
colName='CheckBox06' ><![CDATA[False]]></changedValue>
colName='CheckBox07' ><![CDATA[False]]></changedValue>
colName='CheckBox08' ><![CDATA[False]]></changedValue>
colName='CheckBox09' ><![CDATA[False]]></changedValue>
colName='CheckBox10' ><![CDATA[False]]></changedValue>
colName='CheckBox11' ><![CDATA[False]]></changedValue>
colName='CheckBox12' ><![CDATA[False]]></changedValue>
colName='CheckBox13' ><![CDATA[False]]></changedValue>
colName='CheckBox14' ><![CDATA[False]]></changedValue>
colName='CheckBox15' ><![CDATA[False]]></changedValue>
colName='CheckBox16' ><![CDATA[False]]></changedValue>
colName='CheckBox17' ><![CDATA[False]]></changedValue>
colName='CheckBox18' ><![CDATA[False]]></changedValue>
colName='CheckBox19' ><![CDATA[False]]></changedValue>
colName='CheckBox20' ><![CDATA[False]]></changedValue>
colName='ShortChar01' ><![CDATA[]]></changedValue>
colName='ShortChar02' ><![CDATA[]]></changedValue>
colName='ShortChar03' ><![CDATA[]]></changedValue>
colName='ShortChar04' ><![CDATA[]]></changedValue>
colName='ShortChar05' ><![CDATA[]]></changedValue>
colName='ShortChar06' ><![CDATA[]]></changedValue>
colName='ShortChar07' ><![CDATA[]]></changedValue>
colName='ShortChar08' ><![CDATA[]]></changedValue>
colName='ShortChar09' ><![CDATA[]]></changedValue>
colName='ShortChar10' ><![CDATA[]]></changedValue>
colName='DisplaySeq' ><![CDATA[1]]></changedValue>
colName='KitParentLine' ><![CDATA[1]]></changedValue>
colName='KitAllowUpdate' ><![CDATA[False]]></changedValue>
colName='KitShipComplete' ><![CDATA[False]]></changedValue>
colName='KitBackFlush' ><![CDATA[False]]></changedValue>
colName='KitPrintCompsPS' ><![CDATA[False]]></changedValue>
colName='KitPrintCompsInv' ><![CDATA[False]]></changedValue>
colName='KitPricing' ><![CDATA[]]></changedValue>
colName='KitQtyPer' ><![CDATA[0]]></changedValue>
colName='SellingFactorDirection' ><![CDATA[D]]></changedValue>
colName='RepRate1' ><![CDATA[0]]></changedValue>
colName='RepRate2' ><![CDATA[0]]></changedValue>
colName='RepRate3' ><![CDATA[0]]></changedValue>
colName='RepRate4' ><![CDATA[0]]></changedValue>
colName='RepRate5' ><![CDATA[0]]></changedValue>
colName='RepSplit1' ><![CDATA[100]]></changedValue>
colName='RepSplit2' ><![CDATA[0]]></changedValue>
colName='RepSplit3' ><![CDATA[0]]></changedValue>
colName='RepSplit4' ><![CDATA[0]]></changedValue>
colName='RepSplit5' ><![CDATA[0]]></changedValue>
colName='DemandContractLine' ><![CDATA[0]]></changedValue>
colName='CreateNewJob' ><![CDATA[False]]></changedValue>
colName='DoNotShipBeforeDate' ><![CDATA[]]></changedValue>
colName='GetDtls' ><![CDATA[False]]></changedValue>
colName='DoNotShipAfterDate' ><![CDATA[]]></changedValue>
colName='SchedJob' ><![CDATA[False]]></changedValue>
colName='RelJob' ><![CDATA[False]]></changedValue>
colName='EnableCreateNewJob' ><![CDATA[False]]></changedValue>
colName='EnableGetDtls' ><![CDATA[False]]></changedValue>
colName='EnableSchedJob' ><![CDATA[False]]></changedValue>
colName='EnableRelJob' ><![CDATA[False]]></changedValue>
colName='CounterSaleWarehouse' ><![CDATA[]]></changedValue>
colName='CounterSaleBinNum' ><![CDATA[]]></changedValue>
colName='CounterSaleLotNum' ><![CDATA[]]></changedValue>
colName='CounterSaleDimCode' ><![CDATA[]]></changedValue>
colName='DemandDtlRejected' ><![CDATA[False]]></changedValue>
colName='KitFlag' ><![CDATA[]]></changedValue>
colName='KitsLoaded' ><![CDATA[False]]></changedValue>
colName='DemandContractNum' ><![CDATA[0]]></changedValue>
colName='DemandHeadSeq' ><![CDATA[0]]></changedValue>
colName='DemandDtlSeq' ><![CDATA[0]]></changedValue>
colName='ChangedBy' ><![CDATA[]]></changedValue>
colName='ChangeDate' ><![CDATA[]]></changedValue>
colName='ChangeTime' ><![CDATA[0]]></changedValue>
colName='ReverseCharge' ><![CDATA[False]]></changedValue>
colName='TotalReleases' ><![CDATA[0]]></changedValue>
colName='Rpt1UnitPrice' ><![CDATA[0]]></changedValue>
colName='Rpt2UnitPrice' ><![CDATA[0]]></changedValue>
colName='Rpt3UnitPrice' ><![CDATA[0]]></changedValue>
colName='Rpt1Discount' ><![CDATA[0]]></changedValue>
colName='Rpt2Discount' ><![CDATA[0]]></changedValue>
colName='Rpt3Discount' ><![CDATA[0]]></changedValue>
colName='Rpt1AdvanceBillBal' ><![CDATA[0]]></changedValue>
colName='Rpt2AdvanceBillBal' ><![CDATA[0]]></changedValue>
colName='Rpt3AdvanceBillBal' ><![CDATA[0]]></changedValue>
colName='Rpt1ListPrice' ><![CDATA[0]]></changedValue>
colName='Rpt2ListPrice' ><![CDATA[0]]></changedValue>
colName='Rpt3ListPrice' ><![CDATA[0]]></changedValue>
colName='Rpt1OrdBasedPrice' ><![CDATA[0]]></changedValue>
colName='Rpt2OrdBasedPrice' ><![CDATA[0]]></changedValue>
colName='Rpt3OrdBasedPrice' ><![CDATA[0]]></changedValue>
colName='ExtPriceDtl' ><![CDATA[0]]></changedValue>
colName='DocExtPriceDtl' ><![CDATA[0]]></changedValue>
colName='Rpt1ExtPriceDtl' ><![CDATA[0]]></changedValue>
colName='Rpt2ExtPriceDtl' ><![CDATA[0]]></changedValue>
colName='Rpt3ExtPriceDtl' ><![CDATA[0]]></changedValue>
colName='SysRowID' ><![CDATA[]]></changedValue>
colName='SysRevID' ><![CDATA[0]]></changedValue>
colName='BitFlag' ><![CDATA[0]]></changedValue>
colName='LineStatus' ><![CDATA[]]></changedValue>
colName='InUnitPrice' ><![CDATA[0]]></changedValue>
colName='DocInUnitPrice' ><![CDATA[0]]></changedValue>
colName='InDiscount' ><![CDATA[0]]></changedValue>
colName='DocInDiscount' ><![CDATA[0]]></changedValue>
colName='InListPrice' ><![CDATA[0]]></changedValue>
colName='DocInListPrice' ><![CDATA[0]]></changedValue>
colName='InOrdBasedPrice' ><![CDATA[0]]></changedValue>
colName='DocInOrdBasedPrice' ><![CDATA[0]]></changedValue>
colName='Rpt1InUnitPrice' ><![CDATA[0]]></changedValue>
colName='Rpt2InUnitPrice' ><![CDATA[0]]></changedValue>
colName='Rpt3InUnitPrice' ><![CDATA[0]]></changedValue>
colName='Rpt1InDiscount' ><![CDATA[0]]></changedValue>
colName='Rpt2InDiscount' ><![CDATA[0]]></changedValue>
colName='Rpt3InDiscount' ><![CDATA[0]]></changedValue>
colName='Rpt1InListPrice' ><![CDATA[0]]></changedValue>
colName='Rpt2InListPrice' ><![CDATA[0]]></changedValue>
colName='Rpt3InListPrice' ><![CDATA[0]]></changedValue>
colName='Rpt1InOrdBasedPrice' ><![CDATA[0]]></changedValue>
colName='Rpt2InOrdBasedPrice' ><![CDATA[0]]></changedValue>
colName='Rpt3InOrdBasedPrice' ><![CDATA[0]]></changedValue>
colName='InExtPriceDtl' ><![CDATA[0]]></changedValue>
colName='DocInExtPriceDtl' ><![CDATA[0]]></changedValue>
colName='Rpt1InExtPriceDtl' ><![CDATA[0]]></changedValue>
colName='Rpt2InExtPriceDtl' ><![CDATA[0]]></changedValue>
colName='Rpt3InExtPriceDtl' ><![CDATA[0]]></changedValue>
colName='CurrSymbol' ><![CDATA[]]></changedValue>
colName='BaseCurrSymbol' ><![CDATA[]]></changedValue>
colName='CurrencySwitch' ><![CDATA[True]]></changedValue>
colName='OnHandQuantity' ><![CDATA[0]]></changedValue>
colName='AvailableQuantity' ><![CDATA[0]]></changedValue>
colName='TotalShipped' ><![CDATA[0]]></changedValue>
colName='ExtPrice' ><![CDATA[0]]></changedValue>
colName='MiscCharges' ><![CDATA[0]]></changedValue>
colName='TotalPrice' ><![CDATA[0]]></changedValue>
colName='DocExtPrice' ><![CDATA[0]]></changedValue>
colName='DocMiscCharges' ><![CDATA[0]]></changedValue>
colName='DocTotalPrice' ><![CDATA[0]]></changedValue>
colName='Configured' ><![CDATA[]]></changedValue>
colName='QuoteQtyNum' ><![CDATA[0]]></changedValue>
colName='WarehouseCode' ><![CDATA[]]></changedValue>
colName='BinNum' ><![CDATA[]]></changedValue>
colName='LotNum' ><![CDATA[]]></changedValue>
colName='DimCode' ><![CDATA[]]></changedValue>
colName='DimConvFactor' ><![CDATA[1]]></changedValue>
colName='DUM' ><![CDATA[]]></changedValue>
colName='ProcessQuickEntry' ><![CDATA[False]]></changedValue>
colName='CounterSale' ><![CDATA[False]]></changedValue>
colName='AvailPriceLists' ><![CDATA[]]></changedValue>
colName='ProcessCounterSale' ><![CDATA[False]]></changedValue>
colName='PartTrackLots' ><![CDATA[False]]></changedValue>
colName='PartTrackDimension' ><![CDATA[False]]></changedValue>
colName='DemandQuantity' ><![CDATA[0]]></changedValue>
colName='AvailUMFromQuote' ><![CDATA[]]></changedValue>
colName='FromQuoteLineFlag' ><![CDATA[False]]></changedValue>
colName='MultipleReleases' ><![CDATA[False]]></changedValue>
colName='PartExists' ><![CDATA[False]]></changedValue>
colName='SalesRepName1' ><![CDATA[Chuck Tharpe]]></changedValue>
colName='SalesRepName2' ><![CDATA[]]></changedValue>
colName='SalesRepName3' ><![CDATA[]]></changedValue>
colName='SalesRepName4' ><![CDATA[]]></changedValue>
colName='SalesRepName5' ><![CDATA[]]></changedValue>
colName='WarehouseDesc' ><![CDATA[]]></changedValue>
colName='CreditLimitMessage' ><![CDATA[]]></changedValue>
colName='CreditLimitSource' ><![CDATA[]]></changedValue>
colName='KitFlagDescription' ><![CDATA[]]></changedValue>
colName='KitDisable' ><![CDATA[False]]></changedValue>
colName='KitStandard' ><![CDATA[False]]></changedValue>
colName='KitChangeParms' ><![CDATA[False]]></changedValue>
colName='PriceListCodeDesc' ><![CDATA[]]></changedValue>
colName='EnableSellingQty' ><![CDATA[True]]></changedValue>
colName='TaxAmt' ><![CDATA[0]]></changedValue>
colName='DocTaxAmt' ><![CDATA[0]]></changedValue>
colName='EnableKitUnitPrice' ><![CDATA[False]]></changedValue>
colName='CurrencyCode' ><![CDATA[USD]]></changedValue>
colName='KitOrderQtyUOM' ><![CDATA[]]></changedValue>
colName='Rpt1MiscCharges' ><![CDATA[0]]></changedValue>
colName='Rpt2MiscCharges' ><![CDATA[0]]></changedValue>
colName='Rpt3MiscCharges' ><![CDATA[0]]></changedValue>
colName='Rpt1TaxAmt' ><![CDATA[0]]></changedValue>
colName='Rpt2TaxAmt' ><![CDATA[0]]></changedValue>
colName='Rpt3TaxAmt' ><![CDATA[0]]></changedValue>
colName='Rpt1TotalPrice' ><![CDATA[0]]></changedValue>
colName='Rpt2TotalPrice' ><![CDATA[0]]></changedValue>
colName='Rpt3TotalPrice' ><![CDATA[0]]></changedValue>
colName='ThisOrderInvtyQty' ><![CDATA[0]]></changedValue>
colName='InvtyUOM' ><![CDATA[]]></changedValue>
colName='HasComplement' ><![CDATA[False]]></changedValue>
colName='HasUpgrade' ><![CDATA[False]]></changedValue>
colName='HasDowngrade' ><![CDATA[False]]></changedValue>
colName='HasSubstitute' ><![CDATA[False]]></changedValue>
colName='Rpt1ExtPrice' ><![CDATA[0]]></changedValue>
colName='Rpt2ExtPrice' ><![CDATA[0]]></changedValue>
colName='Rpt3ExtPrice' ><![CDATA[0]]></changedValue>
colName='BaseCurrencyID' ><![CDATA[USD]]></changedValue>
colName='CurrencyID' ><![CDATA[USD]]></changedValue>
colName='POLineRef' ><![CDATA[]]></changedValue>
colName='EntryProcess' ><![CDATA[]]></changedValue>
colName='DspUnitPrice' ><![CDATA[0]]></changedValue>
colName='DocDspUnitPrice' ><![CDATA[0]]></changedValue>
colName='Rpt1DspUnitPrice' ><![CDATA[0]]></changedValue>
colName='Rpt2DspUnitPrice' ><![CDATA[0]]></changedValue>
colName='Rpt3DspUnitPrice' ><![CDATA[0]]></changedValue>
colName='DspDiscount' ><![CDATA[0]]></changedValue>
colName='DocDspDiscount' ><![CDATA[0]]></changedValue>
colName='Rpt1DspDiscount' ><![CDATA[0]]></changedValue>
colName='Rpt2DspDiscount' ><![CDATA[0]]></changedValue>
colName='Rpt3DspDiscount' ><![CDATA[0]]></changedValue>
colName='LessDiscount' ><![CDATA[0]]></changedValue>
colName='DocLessDiscount' ><![CDATA[0]]></changedValue>
colName='Rpt1LessDiscount' ><![CDATA[0]]></changedValue>
colName='Rpt2LessDiscount' ><![CDATA[0]]></changedValue>
colName='Rpt3LessDiscount' ><![CDATA[0]]></changedValue>
colName='InMiscCharges' ><![CDATA[0]]></changedValue>
colName='DocInMiscCharges' ><![CDATA[0]]></changedValue>
colName='Rpt1InMiscCharges' ><![CDATA[0]]></changedValue>
colName='Rpt2InMiscCharges' ><![CDATA[0]]></changedValue>
colName='Rpt3InMiscCharges' ><![CDATA[0]]></changedValue>
colName='InPrice' ><![CDATA[False]]></changedValue>
colName='ContractCodeContractDescription' ><![CDATA[]]></changedValue>
colName='CustNumCustID' ><![CDATA[JIF102]]></changedValue>
colName='CustNumName' ><![CDATA[Joe Cross]]></changedValue>
colName='CustNumBTName' ><![CDATA[Joe Cross]]></changedValue>
colName='MktgCampaignIDCampDescription' ><![CDATA[Base]]></changedValue>
colName='MktgEvntEvntDescription' ><![CDATA[Default]]></changedValue>
colName='OrderNumCardMemberName' ><![CDATA[]]></changedValue>
colName='OrderNumCurrencyCode' ><![CDATA[USD]]></changedValue>
colName='PartNumPartDescription' ><![CDATA[]]></changedValue>
colName='PartNumSellingFactor' ><![CDATA[1]]></changedValue>
colName='PartNumTrackSerialNum' ><![CDATA[False]]></changedValue>
colName='PartNumPricePerCode' ><![CDATA[E]]></changedValue>
colName='PartNumTrackDimension' ><![CDATA[False]]></changedValue>
colName='PartNumIUM' ><![CDATA[]]></changedValue>
colName='PartNumSalesUM' ><![CDATA[]]></changedValue>
colName='PartNumTrackLots' ><![CDATA[False]]></changedValue>
colName='ProdCodeDescription' ><![CDATA[]]></changedValue>
colName='ProjectIDDescription' ><![CDATA[]]></changedValue>
colName='QuoteNumCurrencyCode' ><![CDATA[]]></changedValue>
colName='SalesCatIDDescription'
><![CDATA[Multi-Location]]></changedValue>
colName='TaxCatIDDescription' ><![CDATA[]]></changedValue>
colName='WarrantyCodeWarrDescription' ><![CDATA[]]></changedValue>
colName='RowIdent' ><![CDATA[]]></changedValue>
colName='RowMod' ><![CDATA[A]]></changedValue>
colName='DBRowIdent' ><![CDATA[]]></changedValue>
</paramDataSet>
</tracePacket>
<tracePacket>
<businessObject>Epicor.Mfg.BO.Part</businessObject>
<methodName>GetByID</methodName>
<returnType>Epicor.Mfg.BO.PartDataSet</returnType>
<localTime>02/23/2011 15:53:21:1593711 PM</localTime>
<executionTime>281.2464</executionTime>
<parameters>
</parameters>
</tracePacket>
<tracePacket>
<methodName>ChangeSellingQuantity</methodName>
<localTime>02/23/2011 15:53:27:1905439 PM</localTime>
<executionTime>406.2448</executionTime>
<parameters>
><SalesOrderDataSet
/></parameter>
<parameter name='lKeepUnitPrice' type='System.Boolean'
<parameter name='ipSellingQuantity' type='System.Decimal'
><![CDATA[1.00]]></parameter>
<parameter name='opWarningMsg' type='System.String'
</parameters>
colName='LineDesc' ><![CDATA[Sales Order Additional
colName='ProdCode' ><![CDATA[Other]]></changedValue>
colName='PricePerCode' ><![CDATA[E]]></changedValue>
colName='TaxCatID' ><![CDATA[S0000000]]></changedValue>
colName='ProjectID' ><![CDATA[JIF102--]]></changedValue>
colName='BasePartNum' ><![CDATA[AdditionalCharges]]></changedValue>
colName='Warranty' ><![CDATA[True]]></changedValue>
<changedValue tableName='OrderDt<br/><br/>(Message over 64 KB, truncated)
The one thing I can think of is that you are not notifying the data views
when there are changes... Try calling notify after each BO call and see if
that changes anything?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> lines.
> Ray
> try
> int li_orderNum;
> string ls_partnum;
> string ls_uom="";
> string ls_msg="";
> string ls_msgType;
> bool lbln_isAvail;
> li_orderNum = (int)
> ls_partnum,
> ls_msg);
> try
> that the
> _edvOrderDtl.Row=0;
> ex.ToString());
> ls_partnum;
> (decimal)1.00;
> "0";
> "S0000000";
> // update
> // update
> // screen refresh
> <tracePacket>
> <parameters>
> ><SalesOrderDataSet
> /></parameter>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><SalesOrderDataSet
> /></parameter>
> </parameters>
> </paramDataSet>
> </tracePacket>
> <tracePacket>
> <parameters>
> </parameters>
> </tracePacket>
> <tracePacket>
> <parameters>
> ><SalesOrderDataSet
> /></parameter>
> </parameters>
> <changedValue tableName='OrderDtl' rowState='Added' rowNum=&#
This Worked!!!
This didn't:
_edvOrderDtl.Notify(new EpiNotifyArgs(oTrans,edvOrderDtl.Row,_edvOrderDtl.Column));
Thank You!!
