How to create searchable field in tracker that contains text in
Not sure you explained this correctly... I am kida lost... but you can make
a BAQ with a LIke field to search a MATCHES(*) within a field.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Tue, Jun 25, 2013 at 11:33 AM, rouseyld <laura_rousey@...> wrote:
> Has anyone created (or know if it can be done) a searchable field in a
> tracker that can then be used to search a field in the database view for
> the text that is in the tracker field? I want to search on a specific field
> (column) and want to return all rows where the text is contained in the
> database field.
> Thanks.
> Laura
Has anyone created (or know if it can be done) a searchable field in a tracker that can then be used to search a field in the database view for the text that is in the tracker field? I want to search on a specific field (column) and want to return all rows where the text is contained in the database field.
Thanks.
Laura
