How to Cut a Customer a Check
Unfortunately, there is no out of the box solution to this. There are some options when using a credit cards etc. If it is a one off, then do some manual transactions and record through memos / offline.
Sent: ‎17/‎11/‎2015 18:21
Subject: RE: [Vantage] How to Cut a Customer a Check
<div id="ygrps-yiv-1898348315ygrp-text">
  <p>
It would be nice to have the ability to track that as they are a customer…instead of creating a supplier…
Sent: Tuesday, November 17, 2015 1:09 PM
Make them a vendor in your system….create check….yep that easy!
Manasa
Sent: Tuesday, November 17, 2015 12:29 PM
Subject: [Vantage] How to Cut a Customer a Check
This may be a real "softball" question but we don't know...
We overbilled a customer and need to issue them a check to refund their money.  What are the steps to take to do this?
We know how to create a Credit Memo, but how do we then issue a check against the Credit Memo.
We are on E10.
Cheers,
Charlie Payne
Hendrick Screen Company
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
</div>
[The entire original message is not included.]
We are on E10.
Cheers,
Charlie Payne
Manasa
We are on E10.
Cheers,
Charlie Payne
Manasa
We are on E10.
Cheers,
Charlie Payne
Hhhmmm…may not work this way at all but I may trigger something for you to think about if you are good at programming….
If the IDS were the same (customer and vendor) maybe force a foreign key view to add the vendor tracker info to the customer tracker screen….I don’t think that would work, but there has to be a way to publish the vendor information linked back to the customer screen and vice versa based on the name field or something….I also drank a lot of coffee today so I could be way off my tracker!  J
Manasa
Sent: Tuesday, November 17, 2015 1:21 PM
Manasa
We are on E10.
Cheers,
Charlie Payne
