How to determine a bad BAQ
Blake,
How many folks are writing reports/BAQ's at your organization? Who has created these allegedly faulty BAQs? I.T. should be writing reports and responsible for the results. By IT, I mean one or two people max.
How many custom BAQs do you have approximately? 10? 20? 100? Run the more popular ones (view History in the System Agent) and see if you can duplicate the problem. Keep a log and have users email you when they experience these performance issues. Analyze this log and see if you find patterns. Cross reference with your server.log files and see if you find anything.
Someone mentioned TEST servers.... I do that as normal protocol. That's a necessary thing and a great recommendation. Never deploy a new or modified BAQ unknowingly on a LIVE server (or worst case, not during normal business hrs).
If you are SQL, your TEMP database will inflate faster than Bubble Boy's balloon. That's a clear indication of a malformed BAQ.
Good luck.
Vic
Vic Drecchio
ERP Administrator
TIMCO Aviation Services
Greensboro, NC
Email:Â Â vic.drecchio@...
Mobile:Â 704.530.3092
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Blake Clemens
Sent: Tuesday, December 01, 2009 12:39 PM
Subject: [Vantage] How to determine a bad BAQ
We've been having system performance issues with Vantage from day one.
Now we're being told that our issues are most likely stemming from a
poorly written BAQ/Report. We have to locate the this report and fix
the problem. Sounds easy enough. My question is what makes a
BAQ/Report bad? How do we determine which BAQ/Report? All our
BAQ/reports run without issues and at times run very well. So if there
isn't an obvious indication that something is wrong with the BAQ/Report
how do I determine what makes one bad??
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
If you are on SQL you could run a trace to locate the bad query.
If you are on progress I would run the promon tool to make sure you aren't
having poor DB performance. But there isn't really a tool to pinpoint a bad
query that is running.
~Charlie
_____
Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Lemme throw a perspectives plug in here. In the Sys Ad class, Ben Nixon
said that you create the new BAQ on a test server. Then open your task
manager, and monitor the CPU usage, and the memory usage when you run
that BAQ. You can also monitor your temp folder (/mfgwrk803) for large
DBI files that get created. If your CPU pegs at 100, a very large DBI
file is generated, and your memory takes a hit, then the BAQ is probably
something that you wouldn't wanna run in your live environment.
Of Blake Clemens
Sent: Tuesday, December 01, 2009 11:39 AM
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Also from Perspectives, Mark Pladson had an excellent session on Best Practices for BAQs. There he mentioned if you have a runaway BAQ, you can check your server log and look for a "...long running BAQ..." error with PID of the offending user. It's worth a quick look to see if your server logs give you any clues.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Ditto on Ben Nixon's advice. Are you on Progress or SQL? We're on SQL and rebuilding the indexes helped with performance. The name of the game with Vantage is Disk I/O so don't skimp on that subsystem. It's basically not possible to throw too much hardware at Vantage. There really is no hard rule to determine a bad BAQ. Basically a bad BAQ is one that brings the system to its knees, so test before deploying.
Jared
_______________________
Jared Allmond
IT Systems Administrator
Wright Coating Technologies
jallmond@...<mailto:jallmond@...>
voice: 269.344.8195
direct: 269.341.4353
fax: 269.344.3007
