How to direct Received parts into Inspection
Thanks to all for responding. This has helped direct us in the right direction.
Tom
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of advantage@...
Sent: Friday, July 23, 2010 3:44 PM
Subject: Re: [Vantage] How to direct Received parts into Inspection
Set the part or part class that it belongs to as Inspection Required and then it will go to Inspection Warehouse and in the Inspection Processing queue automatically at Receipt Entry. If it is not set u¶ at those levels it can be set up at Supplier or manually at PO entry
Sent from my Verizon Wireless BlackBerry
Sender: vantage@yahoogroups.com
Date: Fri, 23 Jul 2010 19:20:38
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: [Vantage] How to direct Received parts into Inspection
This is probably a simple question with a simple answer. We can not figure out on how to setup a part to receive directly into inspection. We know how to do it in 6.1, but can figure out how to make it happen in 8.03. The strange thing is that we have a part that is somehow setup like this and can't turn it off. Please let me know what I am missing.
If you will be receiving this part from outside, be sure to check the
inspection required box on the PO\Lines tab.
Tim Dines
ERP Analyst
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Of tom.peat
Sent: Friday, July 23, 2010 3:21 PM
You can also check this on the part class. So if you have a special
class of parts that always have to be inspected go here.
I think the hierarchy is Part and then the Part class. But I could be
wrong on the order and it could be the other way, part class and then
part!
M. Manasa Reddy
manasa@... <mailto:manasa@...>
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Dines, Tim
Sent: Friday, July 23, 2010 2:28 PM
Subject: RE: [Vantage] How to direct Received parts into Inspection
Tim Dines
ERP Analyst
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Behalf
Of tom.peat
Excuse me, I meant the PO and the Part Class, or vice versa!
M. Manasa Reddy
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Of Manasa Reddy
Sent: Friday, July 23, 2010 2:34 PM
part!
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com>
<mailto:manasa@... <mailto:manasa%40weldcoa.com> >
800.852.2325
630.806.2000 ofc
630.806.2001 fax
www.weldcoa.com
Behalf
Of Dines, Tim
Tim Dines
ERP Analyst
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Behalf
Of tom.peat
Set the part or part class that it belongs to as Inspection Required and then it will go to Inspection Warehouse and in the Inspection Processing queue automatically at Receipt Entry. If it is not set u� at those levels it can be set up at Supplier or manually at PO entry
