Question,
Is there a way to populate a list of all products that don’t have a supplier selected? It would show as “TBD”
Thanks in Advance!
Tim
Question,
Thanks in Advance!
Tim
Show it where? In a report?
PartPlant table houses the VenderNum and UrgentVendorNum fields that are assigned on the Part > Site > Planning form.
Not sure if that’s what you’re looking for.
That’s certainly where @snook789 would look to find the current supplier for that part plant record, def a start.
Just not sure where @snook789 is looking to see “TBD” show up.
I assume they created a generic supplier called “TBD”. We did that to assign to various subcontract operations, haha.
yeah that makes sense, well then this is pretty easy if they already have that filled in, or even if it’s left blank.
@snook789 what are you asking for here? subcontract ops that don’t have a supplier yet? BTO parts on the fly that don’t have a supplier yet? regular parts that don’t have a supplier assigned in the part plant record like @dcamlin commented?
You would have to create a dummy Supplier called TBD (or whatever you want to name it), since the field in question can ONLY display a Supplier ID and name.
The easiest way to populate all the PartPlant records that don’t have that informaiton would be to: (1) create a BAQ to get those records, and (2) run a DMT to update them.
Thanks for the replies everyone!
If we don’t have a supplier selected for a product, it is listed as TBD.
I want to go through all the products we have and make sure their is supplier attached to it.
Does this explain it okay?
Yeah, so if you’re still working on this, I would just do a BAQ based on the above.
PartPlant, include PartNum, VendorNum, and/pr UrgentVendorNum.
Just set a table criteria for VendorNum = “TBD” and it should return those corresponding PartNums.
