Is there a date showing in the Check Register? You could then create the fiscal period for this period.
Stephen Schaefer
Stephen Schaefer
--- In vantage@yahoogroups.com, "kayd.indaco" <kay.d@...> wrote:
> We created a manual check last month that posted only the cash side of the entry. The debit/expense side of the entry posted to Retained Earnings for some date prior to 2007 when we implemented Vantage. We don't know the date in la-la land because we get a message that says something like we can't look at any date prior to established fiscal periods. When we look at the transaction in A/P, all dates appear to be correct. However, a query suggests that no posting occurred and no check number was assigned. But you can run an A/P check register and the check is listed. Has anyone run across this before and how can we fix it?
