I have also found that when the DSN you created the Crystal report
under is named differently from what the DSN is named on a client
that the report will not work on the client machine.
David
David
--- In vantage@yahoogroups.com, "Manasa Reddy" <manasa@...> wrote:
> I had this happen to me, took me 2 hours to figure it out, my report
> name was different than the what was in the path( the report path
field
> in menu maintenance)....BY ONE LOUSY CHARACTER!
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> Of Ian Poulsen
> Sent: Monday, January 07, 2008 11:41 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: How to get a Crystal report file RPT to be
usable
> from Vantage Screen?
> Thanks Kersten:
> I did get that far already. In frustration I did not tell the full
> story.
> I am able to get the menu item added. I am able to get the report
to
> work just fine in crystal. I believe that my problem is with the
DSN
> and login. My report is on the menu and when clicked it opens a
> small screen allowing me to use existing account info or put in my
> own. Either with sysprogress or the default existing it will give
me
> an error: Load report failed.
> Under Inner exception:
> The filename, directory name, or volume label syntax is incorrect.
> So, my very general post was to see if there are any preexisting
docs
> that show how to get a report "preped and ready" for Vantage 8.03x.
> I believe that I am missing something simple...maybe not!
> Thanks
> Ian
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Kersten MacLennan" <kmaclennan@>
> wrote:
> > You need to go to menu maintenance and add the item
> > You need to be sitting on the folder that you want to add the
> report to.
> > If you are resting on another report you will create another sub
> > directory.
> > I hope this helps
> > Kersten MacLennan
> > IT/ERP Analyst
> > Semrock, Inc.
> > 3625 Buffalo Rd.,
> > Suite 6
> > Rochester, NY 14624
> > 585-594-7009
> > 585-594-7095 fax
> > kmaclennan@
> > The Standard in Optical Filters for Biotech & Analytical
> Instrumentation
> > Hundreds of Thousands of Ion Beam Sputtered filters delivered -
> > extensive inventory now!
> > The information contained in this message and any attachments may
be
> > privileged, confidential, and protected from disclosure. If the
> reader
> > of this message is not the intended recipient, or any agent
> responsible
> > for delivering this message to the intended recipient, you are
> hereby
> > notified that any dissemination, distribution, or copying of this
> > communication may be unlawful and therefore strictly prohibited.
If
> you
> > received this message in error, please reply to the message and
> delete
> > it. Thank you
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ] On
> Behalf
> > Of Ian Poulsen
> > Sent: Sunday, January 06, 2008 9:12 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] How to get a Crystal report file RPT to be
usable
> > OK, what I thought was an easy issue is not.
> > This is what I have:
> > a Vantage 8.x server running with Live and Train DBs.
> > I have a crystal 2008 (simple) report in .rpt format.
> > I would like to get the report to be accessible from the vantage
> menu
> > system. please let me know where I need to start here.
> > Thanks, much.
> > Ian
