How to get payroll tax the employer pays to post expense by depa
The only other thing I can think of would be to alter the posting rules
for payroll. You would probably have to get CSG (Custom Services Group)
involved, but that is the only way I can think to do it. The rule would
have to alter the G/L control expense account for the employee
division/department
Charlie Smith
2W Technologies LLC, Sr. Business Consultant
Phone: (312) 533-4033 x8046
(860) 620-9553
Fax: (847) 374-3620
2W Tech on Facebook
<http://www.facebook.com/pages/Chicago-IL/2W-Technologies-LLC/1391945694
32409> www.2WTech.com <http://www.2wtech.com/>
Of Tim Vonderhaar
Sent: Friday, October 21, 2011 10:04 AM
Subject: [Vantage] Re: How to get payroll tax the employer pays to post
expense by department
Thanks Charlie. We had tried that and ran into the same limitation.
Being new with Epicor, it sure seems strange when functionality gets
removed as the product is supposed to be evolving.
"CharlieSmith" <CSmith@...> wrote:
> Forget my earlier post. E9 does not allow multiple employer taxes like
> that any more.
> Charlie Smith
> (860) 620-9553
> Fax: (847) 374-3620
> 2W Tech on Facebook
Behalf
> Of Tim Vonderhaar
> Sent: Thursday, October 20, 2011 1:07 PM
post
> Bump. Should I assume by no response that this isn't possible?
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> <
mailto:vantage%40yahoogroups.com> , "Tim
> Vonderhaar" <tvonderhaar@> wrote:
> > We are working on setting up our payroll system in 9.05 and have run
> into a snag. When we create taxes, it appears to only allow
associating
> with a single GL Control. As an example, FICA, we would like this tax
to
> post to the employees department rather than a global FICA expense
> account. We found a way to do this with with labor expense using pay
> type labor expense codes. Is there a way to do this with taxes?
> > Thanks,
> > Tim
We are working on setting up our payroll system in 9.05 and have run into a snag. When we create taxes, it appears to only allow associating with a single GL Control. As an example, FICA, we would like this tax to post to the employees department rather than a global FICA expense account. We found a way to do this with with labor expense using pay type labor expense codes. Is there a way to do this with taxes?
Tim
> Thanks,
> Tim
I don't think so, we run don't have to deal with that, but it doesn't
seem feasible.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Thu, Oct 20, 2011 at 1:06 PM, Tim Vonderhaar <
> > Thanks,
> > Tim
In a matter of speaking, yes and no.
How many departments are we talking about?
The way I have done it in the past would be to create separate Employer
Taxes for each department MDXXX, FIXXX ( or XXXMD, XXXFI to group the
taxes together) with the control code pointing to the accrual and
expense accounts you want to use. Then assign that tax to the employee
taxes. If he crosses over in a week, you might have to journalize the
cross over or changes department you would have to update the tax. That
is the best I have been able to do with it.
Charlie Smith
(860) 620-9553
Fax: (847) 374-3620
2W Tech on Facebook
Of Tim Vonderhaar
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Tim
> Thanks,
> Tim
that any more.
Charlie Smith
(860) 620-9553
Fax: (847) 374-3620
2W Tech on Facebook
Of Tim Vonderhaar
> Thanks,
> Tim
Actually, we have ours setup that way in 6.1....
I can't find the notes anymore, but I'll try to help in 6.1 terms -
hopefully you can find the related fields.
Under the G/L / Departments - setup your departments - for example, we have:
FABRICATION, WELDING, PAINT, ACCOUNTING, etc.
In Chart Maintenance - for example, we have a 000-60610 Account for Mfg.
Expense - Emp FICA. You can go into that and add
"subdivisions", and using the same DEPARTMENT # as above, add your category.
So, ours is broke up under the 60610 account with
010 FAB, 020 WLD, 030 PNT, etc. Same thing for our FUTA/SUTA. Then we have
a G&A account grouping for administration which does
the same breakdown.
Then under each employee - you have to specify their DEPT.
I think that was all there was, but it has been quite awhile ago, so I hope
it helps!
Julie Lehmann
Mercury Minnesota Inc.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, October 20, 2011 12:08 PM
Subject: Re: [Vantage] Re: How to get payroll tax the employer pays to post
> seem feasible.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
>> > into
>> found
>> codes.
>> > Thanks,
>> > Tim
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Thanks Charlie. We had tried that and ran into the same limitation. Being new with Epicor, it sure seems strange when functionality gets removed as the product is supposed to be evolving.
> that any more.
> Charlie Smith
> (860) 620-9553
> Fax: (847) 374-3620
> 2W Tech on Facebook
> Of Tim Vonderhaar
> > Thanks,
> > Tim
