How to import Bill of Operations using DMT
Schitts Creek Please GIF by CBC
Did you have a problems using that DMT? Or something else someone can help with?
The template builder will tell you what’s required for that DMT. If that’s what you’re asking.
DMT ECOOpr no response ,why
Hi chaddb:
What could be the reason that the client cannot import but it can be imported on the server?
have you tried .csv?
or tried this:
Hi Jbooker:
If it works on the server, but not on the client then I would check the server logs for the app server and see if there are nuggets there. I was going upload my ten years tested for mat that has done hundred of thousands of uploads, but if that file works on the server it another issue.
Hi gpayne
Could you upload the file for my reference? Thank you
Does the regular epicor client work on your workstation?
Do other DMTs upload successfully from your workstation?
Everything else is fine except this one
This is what I typically use
E10 BOOs.xlsx (12.2 KB)
Are you using the same user on the server vs. client?
thanks
Yes
