How to install E9.05 with separate App Server
Thanks Ned;
I am referring to the document from Epicor entitled: TechRefGuide_PerformanceTuningVirtual_905602.pdf
This guide outlines seperate "AppServer" boxes that are all load balanced. I am familiar with the seperate AppServers in the PET for departments etc. but this layout seems to make sense to me. If you can e-mail me offline, I can send you the document if you cannot find it. Send me a message to forums@... and I will reply back with the document. Worthwhile reading.
Regards,
George Hicks
--- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@...> wrote:
> You need to define what you mean by AppServers and where this is based on an
> actual need or just want to try it out to see how it would and could work.
> Do you mean a complete secondary hardware server with OpenEdge AppServers on
> it, or do you mean multiple AppServers on the same server?
> Also, in general I haven't seen the need for a company to actually setup
> multiple physical hardware servers to handle the load, performance could
> actually be negatively impacted due to inability to fully utilize the
> benefits of shared memory, while the option of multiple AppServers on the
> same physical server has been beneficial.
> In either case, the use of the AppServers is determined by the client
> installation and the .mfgsys file used for the startup of the AppServers.
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> pcivantage
> Sent: Tuesday, December 21, 2010 5:47 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] How to install E9.05 with seperate App Server.
> I want to lean towards setting up E9.05 to use a cluster of App Servers, so
> I want to set it up initially with one, and then can expand to more.
> Would I install the OpenEdge stuff on the "App Server" and then the Epicor
> Server Software on the "E9" Server? If so, how do you tell the "E9" Server
> to use the "App Server".
> What steps would I use to install fresh with seperated Epicor Server and OE
> App Server.
> Regards,
> George Hicks
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
pcivantage
App Server.
Regards,
George Hicks
