How To: Kinetic Dashboard Uplifts
Great! I will use this post a lot.
I have a question, uplifted a dashboard which had “From Date” and “To Date” filters in the tracker. The “From Date” is showing in the slide out but the “To Date” is not since I added using customization. Are there any instruction on how to add the “To Date” filter in Application Studio?
That is one thing that’s easier to do in App Studio than it was in Classic! You need to edit the layer and add the date-picker then tie it to the field. It’s covered in the OP
I added a new date picker, but when I update the From Date it updates the To Date with the same date.
You need to change the binding to something else and then make sure your grid is set up to filter on that (pub/sub section).
There’s also this:
Thank you, Hannah!
