Thank you very much! It worked!
Hi,
I am using Epicor version 10, and for example I want to create a new "Part", and when I click the "New Part" button I want to have "Quantity Bearing", Phantom BOM" checkboxes already checked so I do not have to check them every time I want to create a new part.
I tried with the dev mode, but I could not find where to make the actual change.
Does any one know?
Hi you want to look at BPMs for this. You can put a post processing BPM on GetNewPart which will set the CheckBox = true. Very simple and straight forward with one of the wizards.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Mon, Nov 9, 2015 at 4:38 PM, ionut.rus@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p><span>Hi,</span></p><p><span><br></span></p><p><span>I am using Epicor version 10, and for example I want to create a new "Part", and when I click the "New Part" button I want to have "Quantity Bearing", Phantom BOM" checkboxes already checked so I do not have to check them every time I want to create a new part.</span></p><p><span>I tried with the dev mode, but I could not find where to make the actual change.</span></p><p><span>Does any one know?</span></p><p><span><br></span></p><p><span>Thanks</span></p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
That sounds more appropriate for a BPM on ‘Part.GetNew’
Rob Bucek
Production Control Manager
D&S Manufacturing
301 E. Main St. | PO Box 279
Black River Falls, WI 54615
715-284-5376 Ext. 311
Mobile: 715-896-3119
rbucek@...
www.dsmfg.com<http://www.dsmfg.com>
Sent: Monday, November 9, 2015 3:38 PM
Subject: [Vantage] how to make default checkboxes
Hi,
Does any one know?
Rob Bucek
D&S Manufacturing
rbucek@...
Hi,
Does any one know?
