How to make Kinetic Dashboard show more than 10 results
I am not sure if this is a bug or a setting i need to find.
I have a Deployed kinetic dashboard that shows me open shop floor labor. From the links on the client, I get full results. I have added a button to MES, and linked it to the menu, and it pulls up but only shows 10 results (even though there should be about 16).
It is NOT scrollable. If I enter the employee id that is not showing, it will pull it up, so the data is there, it just seems that it is only viewing 10 results at a time.
Is there a way to increase the row results to more than 10? I am assuming it is done in app studio but I have tried a number of things which have not worked.
My customization layer is being used, and I can verify that by turning on and off certain check boxes and publishing the layer, I just cant find the row results.
Thanks!
Hello Partick,
You’ll need to add more rows in gride model.
change the “Page Size”
