If you don't get the subprocess dialog box then you need two customisations a blank one on the project form and then customize the attachment form and create a customization with the same name as the one you created on the project form. I hope that makes sense.
It's on of those "Customization Gotchas" according to Epicor support.
I had to do a similar thing with changing the defaults on the duplicate project form.
If you do get a subprocess dialog then check the ICE guide as it has the steps dealing with that.
I have tested this on 9.05.606a.
Cheers
Simon Hall
Cheers
Simon Hall
--- In vantage@yahoogroups.com, "redrhyno13" <cwineinger@...> wrote:
> I'm looking to customize the UI.Attachments.AttachmentDetailForm that is the attachment form when you right click on the Project in Project Entry.
> I haven't been able to locate this form to customize it.
> Any help is greatly appreciated.
> Epicor 905.700b2 running on SQL
> Regards,
> Chris Wineinger
> Interior Systems Inc.
