How to obtain Dashboard Grid control (701)?
Thanks.  .I did not know about the "EpiGridPanel".
I am more into VB.net, so when I declare Property ReadOnly I cannot combine it WithEvents to proceed further.  Do you know I can use this?
Or even something in C# that uses myGrid. DisplayLayout.UIElement ?....
This is version 701.  Epicor has removed the ability to see the Grid control when customizing a dashboard assembly.
Question is -- where can the reference to the EpiUltraGrid be found?
Prior to v.701, I could do this (as the Grid Control was visible on the Properties sheet):
Dim myGrid as  EpiUltraGrid
myGrid = CType(csm.GetNativeControlReference("0a50631b-72c8-42fb-bc99-7aa2e26f30af"),EpiUltraGrid)
So far, I can only get this:
Dim myViewListPanel as EpiBasePanel
myViewListPanel = CType(csm.GetNativeControlReference("37389d17-53f5-4f50-981d-9f7bf0292544"),EpiBasePanel)
Epicor exposes the grid as a property of the panel. Try this
EpiUltraGrid myGrid
get {
return ((Epicor.Mfg.UI.FrameWork.UIApp.EpiGridPanel)
(csm.PersonalizeCustomizeManager.ControlsHT["88601500-ad6c-4d83-8be8-8c9e8a278ee5"])).EpiGrid;
Then call it as myGrid.XX
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
     Â
On Tue, May 20, 2014 at 10:40 AM, tomdomurat@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p><span style="word-spacing:normal;">This is version 701. Â Epicor has removed the ability to see the Grid control when customizing a dashboard assembly.</span><br></p><p>Question is -- where can the reference to the EpiUltraGrid be found?</p>
</div>
<div style="color:#fff;min-height:0;"></div>
