It sounds to me like you made the parameter but did not put it in the select expert.
--- In vantage@yahoogroups.com, "jckinneman" <jckinneman@...> wrote:
> Can you go into a bit more details on what you built? Did you build a BAQ based report that uses Crystal? Or is this just a crystal report that goes directly to the database? Or?
> If a BAQ report you can put filters on the report so that it only pulls the related PO.
> Jim Kinneman
> Encompass Solutions, Inc.
> --- In vantage@yahoogroups.com, "clederer@" <clederer@> wrote:
> > I created a Crystal Report that prints shipping labels. I have this set up on a tab in Purchase Order Entry. There are 5 custom text boxes that link to a Crystal Report. When you pull up the Crystal Report it prompts you to enter the "Purchase Order Number" then it lets you into the report. Right now it pulls from EVERY SINGLE purchase order in the system, so I end up with 9,000 pages of labels. Ideally, I want 1 label for the PO Number I'm working on. Why does Crystal Reports still pull from the entire database even when I prompt it to pull from ONE purchase order? How do I ONLY get information from that purchase order I'm prompting Crystal prior to it opening the report?
