Of course, team effort, thanks Stephen :)
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> Thanks to Stephen too! :o)
> --- In vantage@yahoogroups.com, "clive.1972" <clive.1972@> wrote:
> > bw,
> > I tweaked the code to sort out the line wrapping and it worked
> first
> > time, brilliant !.
> > Thank you for your help, it's realy appreciated.
> > --- In vantage@yahoogroups.com, "bw2868bond" <bwalker@> wrote:
> > > Here is bare minimum customization: (watch wrapping of text in
> post)
> > > Module Script
> > > '// ** Wizard Insert Location - Do Not Remove 'Begin/End
> > > Wizard Added Module Level Variables' Comments! **
> > > '// Begin Wizard Added Module Level Variables **
> > > Private WithEvents edvPart As EpiDataView
> > > '// End Wizard Added Module Level Variables **
> > > '// Add Custom Module Level Variables Here **
> > > Sub InitializeCustomCode()
> > > '// ** Wizard Insert Location - Do not
> > > delete 'Begin/End Wizard Added Variable Intialization' lines **
> > > '// Begin Wizard Added Variable Intialization
> > > edvPart = CType(oTrans.EpiDataViews("Part"),
> > > EpiDataView)
> > > '// End Wizard Added Variable Intialization
> > > '// Begin Custom Method Calls
> > > edvPart.dataView.Table.Columns
> ("PartNum").ExtendedProperties
> > > ("Like") = False
> > > '// End Custom Method Calls
> > > End Sub
> > > Sub DestroyCustomCode()
> > > delete 'Begin/End Wizard Added Object Disposal' lines **
> > > '// Begin Wizard Added Object Disposal
> > > edvPart = Nothing
> > > '// End Wizard Added Object Disposal
> > > '// Begin Custom Code Disposal
> > > '// End Custom Code Disposal
> > > End Sub
> > > End Module
wrote:
> > > > Hi bw,
> > > > A good example would be 'Part Maintenance', and the text box
> > being
> > > > the one that the part number is displayed on on the Part tab
> > > > (called 'tbPart').
> > > > Thanks.
> > > > > What form - what textbox?
> > > > > I will take a stab at it :o)
> > > > > bw
> > wrote:
> > > > > > Hi Stephen,
> > > > > > I don't know if you missed my reply below ?, if you're
not
> > sure
> > > > of
> > > > > > the next step then that's fine and I'll log a call with
> > > Epicor :)
> > > > > > Thanks.
<clive.1972@>
> > > wrote:
> > > > > > > Stephen, how do I alter this value if it is greyed
out ?.
> > > > > > > Thanks.
> > > > > > > --- In vantage@yahoogroups.com, "Stephen Edginton"
> > > <stephene@>
> > > > > > > wrote:
> > > > > > > > Remove the "like" property from the extended
properties
> > of
> > > > the
> > > > > > data
> > > > > > > > column.
> > > > > > > > From: vantage@yahoogroups.com
> > > > [mailto:vantage@yahoogroups.com]
> > > > > On
> > > > > > > Behalf
> > > > > > > > Of clive.1972
> > > > > > > > Sent: 22 January 2009 15:14
> > > > > > > > To: vantage@yahoogroups.com
> > > > > > > > Subject: [Vantage] How to remove the 'right click ->
> open
> > > > with'
> > > > > > > from a
> > > > > > > > text box on a customisation
> > > > > > > > I want to do a customisation that heavily restricts
> what
> > > can
> > > > be
> > > > > > > done on
> > > > > > > > a program in Vantage (8.03.406a) and a key thing is
to
> > > remove
> > > > > > > > the 'right click -> open with' option from a text box.
> > > > > > > > I don't want to disable the text box though as I
still
> > want
> > > > to
> > > > > > > allow
> > > > > > > > people to type text into it.
> > > > > > > > Can this be done, either with a simple option or some
> > > code ?.
> > > > > > > > Thanks.
> > > > > > > > [Non-text portions of this message have been removed]
