How to see which menu items use a UD field?
Recently I made a UD field (called QuoteRev_c) to replace an old UD field that wasn’t doing what it needed to. I’ve already changed Quote Entry and Tracker so that the new QuoteRev field is used, but there’s still other menu items that are pulling the old field. Is there a solid way to look up every item that calls that field, so I can update them?
