How to subtract a working day
Epicor version 9.05.701
Does anyone know the syntax to subtract 1 working day?
Using dateadd function use -1 to substract.
DateAdd(day, -1, Today)
Look at your function…you have twice the date01… just use
DateAdd(day, -1, porel.Date01)
My apologies - but same error.
I suspect Date01 does not have a value,
But I looked at your original picture…this is a data directive. You should use ttPoRel.Date01 not PORel.Date01 I think. It is that way in version 10, I assume should be in version 9.
You are detecting if ttPORel.Date01 has changed… so there is a value…
Pierre
Hi, i get the same error when i use ttPoRel.Date01
i am on epicor version 9.05.701
Im not sure if the “DateAdd” function is compatible with this version
