Once i go into the BIOS Setup (On the hardware side) it shows the
drives as failed and I have to re-initilize them, reformat them, and
rebuild them!
The local mirror Vantage installation is running off the controller
card built into the motherboard and the motherboard HAS been totally
replaced
Bad point and future point for reference
Our system (no my decision) was purchased thru Micron
Micron's agreement with HP is that HP has a 29 day turn around time
on getting us a new server
Micron is looking into shipping us one of their servers
Anyone using a Micron server out there?
rebuild them!
replaced
--- In vantage@y..., Todd Anderson <tanderson@j...> wrote:
> Hmmm .. one other thing after re-reading your msg ...
> "I have reformatted the drives and done a fresh install on Vantage
> and progress TWICE"
> If you can reformat a drive then the drive probably hasn't "Failed".
> I'd take a good look at your RAID controller - what are you using?
> You might try attaching the drives to your std SCSI controller
without the
> mirror and see what happens. Yes, I know you loose the protection
but it
> might nail down the RAID controller as the offending device.
> Todd Anderson
> -----Original Message-----
> From: meco_inc_paris [mailto:admin@m...]
> Sent: Friday, May 10, 2002 10:47 AM
> To: vantage@y...
> Subject: [Vantage] Re: HP Server Progblems, Can Progress or Vantage
be
> causing this
> I am running NT 4.0
> And I stay away from M$ Pathces as much as possible on my servers
> The Vanatage drives are independant of the OS Drive
> So no I have not did a M$ Patch on it at all
> --- In vantage@y..., "All American Products" <miket@a...> wrote:
> > Is the O.S. NT4.0 or 2K? If it's NT4.0 did you download the
latest
> security
> > patch from Microsoft? If yes, then that's what happened to ours.
In
> our case
> > all 4 drives failed.
> > Mike Tonoyan / All American Products Co.
> > ----- Original Message -----
> > From: "meco_inc_paris" <admin@m...>
> > To: <vantage@y...>
> > Sent: Friday, May 10, 2002 7:22 AM
> > Subject: [Vantage] HP Server Progblems, Can Progress or Vantage
be
> causing
> > this
> > > I have a lengtly problem that I wondered if Vantage or Progress
> could
> > > be causing
> > > To make a long story short
> > > We have a HP LH3000 Net Server
> > > I am running Vantage 5.118 and Progress
> > > I have two 9 gb SCSI Hard Drives with a hardware mirror
> > > I have had problems for two months with the first drive
> > > It keeps failing
> > > I have done EVERYTHING I Can think of!
> > > HP Has replaced EVERYTHING IN the machine
> > > Both Hard Drives
> > > SCSI Back Plane
> > > SCSI Cables
> > > And the motherboard
> > > Guess what
> > > Still having problems with the drives failing
Vantage
> and
> > > progress TWICE
> > > HP Has a 29 day turn around on getting me a new server
> > > While I am waiting and "babying this thing"
> > > I was asked by Micron (Thats who they got the server from)
> > > COuld it be something your software is doing?
> > > I am going to contact Epicor about this but I have been all the
> way
> > > in the hardware configuration and it says that the drives will
not
> > > spin up or initilize or or or
> > > Anyone else had anything similiar?
> > > Thanks
> > > James Piper
> > > Meco Inc
> > > admin@m...
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> must
> > have already linked your email address to a yahoo id to enable
> access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> <http://groups.yahoo.com/group/vantage/files/.>
> > > (2) To search through old msg's goto:
> > http://groups.yahoo.com/group/vantage/messages
> <http://groups.yahoo.com/group/vantage/messages>
> > > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> <http://groups.yahoo.com/group/vantage/links>
> > > Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
<http://docs.yahoo.com/info/terms/>
> Yahoo! Groups Sponsor
> ADVERTISEMENT
<http://rd.yahoo.com/M=194081.2053425.3521449.1829184/D=egroupweb/S=17
050071
> 83:HM/A=1046314/R=1/*http://www.ediets.com/start.cfm?code=3225>
050071
> 83:HM/A=1046314/R=2/*http://www.ediets.com/start.cfm?code=3225>
> Height: 4 5 6 7 ft 0 1 2 3 4 5 6 7 8 9 10 11 in
> Weight:
> Sex: F M
> <http://us.adserver.yahoo.com/l?
M=194081.2053425.3521449.1829184/D=egroupmai
> l/S=1705007183:HM/A=1046314/rand=472753367>
must have
Builder and
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
