I can't select my customization in menu maintenance Epicor Cloud Kinectic
Hello,
I am using Epicor Kinectic Cloud, I created a customization in form AR Invoice Tracker when I saved it I selected the options All Companies, I created my customization in classic version of form. When I go the menu maintenance the field customization is disable and I can’t select my customization. Why can not I select the customization?? How can I able my customization?
The same thing in the parts form.
Thank you.
Regards
You are in a folder there is no customization possible in a folder…
I am sorry , I upload wrong image. I want to select customization of AR Inovice Tracker how you can see in the next image. But the field customization is disabled.
I believe you need to clone it to local company and then select it Action-> Copy Local
Hello @josecgomez
Thank you for you answer. I had to copy it. Do you know why in Epicor Cloud you have to copy the menu and not be able to select the customization from the original menu like in On premise?
Thank you.
Regards
