Hello,
I’m experimenting with using the Ice.SplitDelimString function in an external BAQ and am having some trouble getting it to work. So, I was curious if anyone had any luck using this and how they were able to get it to work.
Hello,
Those helpers in there are SQL functions and they are in the context of your Query. They live in the Epicor DB, if you are using an external Db those helpers will not work.
You have to use your own function here’s the one I use in my external Db
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE Function[SplitDelimString_EXT]
@stringIn NVARCHAR(4000),
@delimiterChar NCHAR(1)
RETURNS TABLE
AS
RETURN
WITH Split(stpos,endpos)
AS(
SELECT 0 AS stpos, CHARINDEX(@delimiterChar,@stringIn) AS endpos
UNION ALL
SELECT endpos+1, CHARINDEX(@delimiterChar,@stringIn,endpos+1)
FROM Split
WHERE endpos > 0
SELECT
'value' = SUBSTRING(@stringIn,stpos,COALESCE(NULLIF(endpos,0),LEN(@stringIn)+1)-stpos)
FROM Split
GO
Once you add it in, then you can use it.
I’m using an external BAQ, but it is pointing to the main Epicor database, these functions are available to me, but I’m not sure how to get a value from a column for the parameter of this function.
That worked perfectly, thank you
Well, I’ve already learned something new today! Does that mean that I can start my weekend early?
Thanks Jose!
#MeToo
I had never used one of these before, seems super useful it would be cool if they worked in non external baqs
