For anyone who works with Epicor IDC DFD mappings: The STRJOIN function can be used in a field formula to concatenate things. I’m using a STRJOIN function for a MultiLine field.
Q: Does anyone know if it’s possible to add a line break within a STRJOIN function?
Thanks for the suggestion. Didn’t work in the IDC DFD function. But my professional services partner will be asking Ancora if there is syntax for their STRJOIN function to add a Line Break. If there is, then I’ll share with the group.
Ancora provided a solution! In the STRJOIN, insert: SQLEXEC(STRJOIN(“select char(13) + char(10)”))
So if I had an IDC DFD MultiLine field and wanted to concatenate the values from the CUSTOMER_NAME and CUSTOMER_ADDRESS fields with a Line Break in-between, the STRJOIN formula would be:
