We did a custom solution for a similar company (they did cutting on Tape
Rolls) it was massive though, they needed to track individual pieces of the
cut and time on both the slitting and the coating ("adding adhesive")
We used several UD tables to track the individual cuts and
product configuration to generate them based on width, length etc...
Definitely doable but a bit a of a monster
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Mon, Aug 22, 2011 at 12:23 PM, jgiese1988 <jgiese@...
*Jose C Gomez*
*Software Engineer*
E: jose@...
> wrote:[Non-text portions of this message have been removed]
> We are using pounds for all of the paper inventory and issuance to a job.
> Note that we are not Live yet.
> --- In vantage@yahoogroups.com, Scott Kaufman <skaufman@...> wrote:
> > Are you using different UOMs for your different slit widths or separate
> part numbers?
> > We are a printing company and inventory many different slit widths for
> many different raw materials. We are on the fence about which direction to
> take.
> > We inventory and issue in feet however.
> > Scott
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> Of jgiese1988
> > Sent: Monday, August 22, 2011 11:03 AM
> > Subject: [Vantage] Re: Ideas for a job
> > Does your company "pre-slit" the jumbo roll into multiple, and different
> width rolls?
> > Some of our colored paper bags are in sizes that we cannot get roll
> widths for and we must slit them down for raw stock.
> > Or slit-to-job just prior to job start?
> > We do this as well for our custom make to order bags
> > As far as scrap is concerned is this the kerf from the slitting process
> and/or from the job?
> > Yes, the scrap would be the kerf and any damaged paper from getting the
> roll setup in the slitter or if the roll
> > tears during the process and they have to re-setup. As far as job scrap
> goes we plan to use the roll weight
> > at the start of a job minus the weight at the end of the job minus the
> expected lbs used and accept the remainder
> > as our scrap if that makes sense.
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Rich"
> different width rolls? Or slit-to-job just prior to job start? As far as
> scrap is concerned is this the kerf from the slittting process and/or from
> the job?
> "jgiese1988" <jgiese@> wrote:
> > > > We have large paper rolls that we cut down into many smaller rolls.
> We would like to be able to attach scrap paper and time to a job, but are
> unsure the best way to go about it. Anyone else have a similar process?
> > CONFIDENTIALITY: The information contained in this email message,
> including any attachment(s), may be privileged and confidential and
> protected from disclosure. The email is not intended for transmission to, or
> receipt by, any unauthorized persons. If the reader of this message is not
> the intended recipient, or an employee or agent responsible for delivering
> this message to the intended recipient, you are hereby notified that any
> dissemination, distribution, or copying of this communication or use of the
> information contained herein is strictly prohibited. If you have received
> this electronic mail transmission in error, please delete it from your
> system without copying or disseminating, and notify the sender by Reply
> email, so that our address record can be corrected.
