IIS 6.0 and Epicor 9 embedded education courses
Yes, I had this same problem with Epicor 9 and the 64 bit server
--- On Fri, 5/22/09, Karen Schoenung <kschoenung@...> wrote:
Subject: RE: [Vantage] IIS 6.0 and Epicor 9 embedded education courses
Date: Friday, May 22, 2009, 4:01 PM
Hi Scott and Bruce,
Now that Bruce mentioned the 64 bit possibility. ..I recall when we first
setup Service Connect on a 64 bit server, we had this
issue...Instruction s provided after the fact, so I have NOT TESTED
these. And of course, you may not need step 3 or you may have different
services to reinstall... Since this is a test environment, you may want
to try these...
Karen
1) Navigate to c:\inetpub\adminscr ipts (cmd prompt)
cscript.exe adsutil.vbs set W3SVC/AppPools/ Enable32BitAppOn Win64 "true"
2) Navigate to C:\WINDOWS\microsof t.net\Framework\ v2.0.50727> (cmd
prompt)
aspnet_regiis. exe -i
3) C:\Epicor\mfgsys803 \WebServices\ WS-Configuration (.Net 2.0 Edition)
Reinstall all services, update site
4) Computer, manage, (IIS) Enable web service extension ASPNET (32-bit).
(click allow button)
5) start > run > iisreset
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Bruce Larson
Sent: Friday, May 22, 2009 2:51 PM
To: vantage@yahoogroups .com
I worked with a company that had this issue and it had to do with their
server which was a 64 bit and there was a setting that had to be
changed.
I'm sorry, I don't know all of the details, but if this is what you are
running I could check the details of the solution for you.
Bruce
www.ERPgeek. com
bruce@ERPgeek. com <mailto:bruce% 40ERPgeek. com>
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf Of
Scott Lepley
Sent: Friday, May 22, 2009 2:28 PM
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Subject: [Vantage] IIS 6.0 and Epicor 9 embedded education courses
I have installed and licensed the embedded education courses in our
Epicor 9
test environment. Unfortunately, whenever I attempt to launch a licensed
course, I receive "The page cannot be found" error message, even though
it
appears that IIS and the EpicorEducation virtual directory are set up
correctly. I have already contacted Support and have made several
attempts
to determine the exact cause of the error and correct the problem, all
without success. Has anyone else encountered this issue and, if so, were
you able to resolve it? Any help would be greatly appreciated!
Regards,
Scott
have
and
http://groups. yahoo.com/ group/vantage/ files/.
<http://groups. yahoo.com/ group/vantage/ files/>
http://groups. yahoo.com/ group/vantage/ messages
http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
I have installed and licensed the embedded education courses in our Epicor 9
course, I receive "The page cannot be found" error message, even though it
correctly. I have already contacted Support and have made several attempts
Regards,
Scott
server which was a 64 bit and there was a setting that had to be changed.
Bruce
www.ERPgeek.com
bruce@...
Scott Lepley
Regards,
Scott
Hi Scott and Bruce,
Now that Bruce mentioned the 64 bit possibility...I recall when we first
issue...Instructions provided after the fact, so I have NOT TESTED
services to reinstall...Since this is a test environment, you may want
to try these...
Karen
1) Navigate to c:\inetpub\adminscripts (cmd prompt)
cscript.exe adsutil.vbs set W3SVC/AppPools/Enable32BitAppOnWin64 "true"
2) Navigate to C:\WINDOWS\microsoft.net\Framework\v2.0.50727> (cmd
prompt)
aspnet_regiis.exe -i
3) C:\Epicor\mfgsys803\WebServices\WS-Configuration (.Net 2.0 Edition)
Of Bruce Larson
changed.
Bruce
www.ERPgeek.com
bruce@... <mailto:bruce%40ERPgeek.com>
Behalf Of
Scott Lepley
Epicor 9
it
attempts
Regards,
Scott
have
and
