Import csv file via Service Connect
If you have CRM, there is also a Customer/Contact Import directly from Epicor that uses a .csv file. The file format is available in Help.
--- In vantage@yahoogroups.com, "P" <pklein@...> wrote:
> DMT is a great tool where if you have the correct column name in your .csv or spreadsheet, and then you click a button to upload the data into Epicor.
> Not every file is available at the different version levels, so at 8.03.xx you might not be able to import/update as many files as at the latest version. We are at version 9.05.605 and I have noticed there are a lot more file layouts available to use DMT.
> We use DMT for 1-time, or occaisional updates, and use service connect if the data is updated on a regular basis.
Hey folks,
I need to import a whole list of customers from a csv file via Service Connect. However, I have never used service connect although it is all setup from my predecessor - is this something straight forward?
I have also looked into the DMT - would this be easier? Is the license expensive for the DMT?
Regards,
Michael
Service Connect is pretty simple. If you've got it already it's really not
worth the trouble/expense of acquiring another tool.
A tip though, when you setup your import, make sure you put a limit on the
number of threads it starts. If you let it try to import everything
asynchronously it can destroy your performance.
On Tue, Jan 17, 2012 at 6:47 AM, michael.hutcheson@... <
michael.hutcheson@...> wrote:
> Hey folks,
> Regards,
> Michael
*John Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Ok thanks, I'm just working through the user guide now...
> > Hey folks,
> > Regards,
> > Michael
> *John Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
mmmmm this isn't as straight forward as I thought - all I want to do is import a list of customers from a csv file.
--- In vantage@yahoogroups.com, "michael.hutcheson@..." <michael.hutcheson@...> wrote:
> Hey folks,
> Regards,
> Michael
That's the way to do it, other than having the DMT tool., you could also
try to use an updatable BAQ (if you are on 9.05) What version are you on?
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Tue, Jan 17, 2012 at 10:23 AM, michael.hutcheson@... <
> > Hey folks,
> > Regards,
> > Michael
Sorry, not laughing at you.... Service Connect is *anything* but straightforward. That’s why I avoid it like the ghetto.
If you’re SQL, I have some import scripts you could use or get ideas from. Otherwise, DMT is more straightforward. Not that Service Connect can’t do what you want, but (for me) creating a Workflow to import 1000 customers takes longer than if I just would have manually typed them all in. There’s 3 things I’m not a fan of: NY Sports teams, my wife’s cooking and Service Connect.
Sent: Tuesday, January 17, 2012 10:23 AM
Subject: [Vantage] Re: Import csv file via Service Connect
--- In mailto:vantage%40yahoogroups.com, "michael.hutcheson@..." <michael.hutcheson@...> wrote:
> Hey folks,
> Regards,
> Michael
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1901 / Virus Database: 2109/4748 - Release Date: 01/17/12
I don’t know what the hell youre talking about…your wife made me a great meal last night…
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
Sent: Tuesday, January 17, 2012 9:36 AM
Subject: Re: [Vantage] Re: Import csv file via Service Connect
From: michael.hutcheson@...<mailto:michael.hutcheson%40rocketmail.com>
> Hey folks,
> Regards,
> Michael
Service Connect is a great tool, but as with all tools, it has applications it’s really good at, and applications it’s not (or it’s overkill). With a one-time import of customers, I think SC is overkill – DMT is your best option. I would not recommend writing directly to the DB.
Kevin Simon
Sent: Tuesday, January 17, 2012 10:36 AM
From: michael.hutcheson@... <mailto:michael.hutcheson%40rocketmail.com>
> Hey folks,
> Regards,
> Michael
Sorry - Vantage 8.03.305L
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > --- In vantage@yahoogroups.com, "michael.hutcheson@"
> > <michael.hutcheson@> wrote:
> > > Hey folks,
> > > Regards,
> > > Michael
I'm on Progress but thank you anyway.
What's wrong with the NY Jets? : -D
> --- In mailto:vantage%40yahoogroups.com, "michael.hutcheson@" <michael.hutcheson@> wrote:
> > Hey folks,
> > Regards,
> > Michael
