Import E9 BAQ with Custom fields?
My developer was looking to import an existing E9 BAQ with UD fields in to Kinetic but he gets an error (Understandably) with this statement “System.IO.FileNotFoundException: Mapping file not found: \SRV-KINPRINT\EpicorData\Companies\STIP\E9DBMapping.xml”
Is that something that should exist to Map custom fields from E9 to Kinetic or should he be doing something else?
Have the custom fields been added to the Kinetic DB yet? Though this usually doesn’t prevent importing the BAQ but maybe it’s a E9 to Kinetic thing.
It could possibly be a browser things as i managed to import via the Client and all it did was say the the custom fields did not exist.
I can’t say I would imagine that would make it onto Epicor’s list of QA tests…
I hope E9 BAQs can be imported via Browser (with the death of Classic coming on fast) . I’m sure all us longtime admins have many exported BAQs that we may need to reference later.
that was a file with renames and other fields changes in DB.
It is probably somewhere in the folder for DB migrations too.
I have one from test folder, you can try it.
Put it in the folder it is looking in.
E9DBMapping.xml (28.4 KB)
