I imported a report encrypt from a test P21 (Cloud) instance, (same version.) The import succeeded but no record was created in Report Studio so believing I had failed, I repeated this four more times, changing the file name and removing characters in case there is a character limitation, with no success, no records appear in Report Studio even after . Then I checked in My Reports, it shows up 5 times. Any idea how I can remove the duplicates since they are not in Report Studio?
Hi Fred,
Is the datasource for this report enabled? That might explain why the report does not appear in Report Studio.
That was it, thanks Simon.
