Importing Access into Vantage (Vantage 5.2)
also my concern about the conversion tool is make sure it will change the
table / fields that you want it to. In Epicor's vast "wisdom" this tool is
only to transfer data from a legacy system into vantage not to maintain
vantage. :)
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Sent: Wednesday, November 10, 2004 2:59 PM
Subject: RE: [Vantage] Importing Access into Vantage (Vantage 5.2)
Carol,
You would never want to update from Access information (database triggers,
data integrity, etc.). Conversion tool will run in the thousands. If you
have the money, it is recommended. If you are budget conscious and have
someone that will spend the time, Ground Control and other macro software
will read your Access information, and do all the clicks, adds, and data
entry for you. Ground control should be about $40.00. You can re-use the
macros whenever you need them. I added and continue adding customer and ship
to maintenance for our partner with over 4,000 customers and 7,000 ship-to
addresses. Also, separated 2 divisions into companies with Ground Control.
I also had the opportunity to do BOM's, but I realized that by creating a
master part and copying the BOM from the master part, it would be easier to
make adjustments than to enter them from scratch (a lot of subassemblies in
the process).
Good luck!
Mario Aguirre
Lakin General Corporation, Inc.
Sent: Wednesday, November 10, 2004 12:28 PM
Subject: [Vantage] Importing Access into Vantage (Vantage 5.2)
Does anyone have experience with importing information from an Access
Database into Vantage?
Has it worked? How easy/difficult is it? Vantage custom services?
We currently have a large quote database in Access and need to make
improvements...possibly by bringing it into Vantage Quoting.
Thank you,
Carol Engen
Controller
Winona Lighting
Phone: 507-454-5113, Ext. 314
Fax: 507-454-4806
e-mail: cengen@... <mailto:cengen@...>
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129uv9522/M=295196.4901138.6071305.3001176/D=gr
oups/S=1705007183:HM/EXP=1100197763/A=2128215/R=0/SIG=10se96mf6/*http:/compa
nion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=
:HM/A=2128215/rand=807051815>
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/> Service.
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129oa8pi0/M=294855.5468653.6549235.3001176/D=gr
oups/S=1705007183:HM/EXP=1100203037/A=2376776/R=0/SIG=11ldm1jvc/*http://prom
otions.yahoo.com/ydomains2004/index.html> click here
<http://us.adserver.yahoo.com/l?M=294855.5468653.6549235.3001176/D=groups/S=
:HM/A=2376776/rand=735492998>
_____
Yahoo! Groups Links
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<www.LCDarms.com> -- Ergonomic mounting solutions for monitors and keyboards
This e-mail is from Innovative Office Products, Inc. but expresses the views of the sender and not necessarily the views of the company. The email and any files transmitted with it are confidential to the intended recipient at the e-mail address to which it has been addressed. It may not be disclosed or used by any other than that addressee, nor may it be copied in any way. If received in error, please delete and notify the sender via e-mail or sales@... quoting the name of the sender. Messages sent via this medium may be subject to delays, non-delivery and unauthorized alteration. This e-mail has been prepared using information believed by the author to be reliable and accurate. Unless expressly stated otherwise, this e-mail does not form part of a legally binding contract or agreement between recipient and Innovative Office Products, Inc.
Warning: Although Innovative Office Products, Inc. has taken reasonable precautions to ensure no viruses are present in this email, we cannot accept responsibility for any loss or damage arising from the use of this email or attachments. It is, therefore, your responsibility to scan attachments (if any).
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
We have looked at this extensively. Our quoting system is Access based. We would really like to import BOM structures into Vantage. But....we have determined that it would require custom programming from Epicor )or someone very knowledgeable in the Vantage DB and Progress), this would be really expensive (minimum $20K), and there would be large inefficiencies remaining (two customer tables, parallel shop configs, lack of reporting, etc...). So for now we exist with two systems. The ray of hope for the future is extreme screen customization capabilities in Vantage 8.0 which will allow us to use native Vantage, by far the best and cleanest solution.
-Todd C.
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129uv9522/M=295196.4901138.6071305.3001176/D=groups/S=1705007183:HM/EXP=1100197763/A=2128215/R=0/SIG=10se96mf6/*http://companion.yahoo.com> click here
<http://us.adserver.yahoo.com/l?M=295196.4901138.6071305.3001176/D=groups/S=:HM/A=2128215/rand=807051815>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
I would think this is a vantage custom, you have to deal with progress db
triggers. They only had to tell me once that any db corruption problems
will be billable on a time and materials basis :-)
Frank Zeigafuse
General Manager
Sent: Wednesday, November 10, 2004 1:28 PM
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
ADVERTISEMENT
_____
Yahoo! Groups Links
I was told by Epicor they will not support imported data from any source
other than their Conversion Tool software so I didn't try. You might
want to contact Epicor about the Conversion Tool to get your data
loaded.
Butch
Sent: Wednesday, November 10, 2004 10:28 AM
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
e-mail: cengen@...
<mailto:cengen@...>
ADVERTISEMENT
click here
Yahoo! Groups Links
ditto, we read from progress but that is all.
how we have worked around this to create our own tables in access or sql and
write to them.
Frank Zeigafuse
General Manager
Sent: Wednesday, November 10, 2004 2:25 PM
loaded.
Butch
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
e-mail: cengen@...
<mailto:cengen@...>
ADVERTISEMENT
click here
Yahoo! Groups Links
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=1290q955c/M=295196.4901138.6071305.3001176/D=gr
oups/S=1705007183:HM/EXP=1100201084/A=2128215/R=0/SIG=10se96mf6/*http://comp
:HM/A=2128215/rand=545017448>
_____
Yahoo! Groups Links
Carol,
the process).
Good luck!
Mario Aguirre
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
ADVERTISEMENT
_____
Yahoo! Groups Links
