Importing MS Project file
Hi,
You have to create a seperate mapping for uploading. I have only tried
this on projects created in vantage and downloaded them into project. I
changed some dates on the phases.
In project save as csv
Create a new mapping as per the error message.
This should upload then. Needs testing though. I have never used it a
fulll full blown scheduling environment where you could changed the
operation dates.
Its a pitty that PO link to projects but not jobs aren't extracted.
If you are using projects I would like to here how you are getting on
with them and the type of business you are in.
Hope this helps.
--- In vantage@yahoogroups.com, "arakawapaul" <paul.arakawa@...> wrote:
> Hello,
> I am using Vantage 6.10 and cannot successfully import MS Project
> files into Vantage. I have tried using the "Project Entry --> Upload
> from MS Project" but get the following error:
> "Invalid MSP Project Import File.
> File should contain: ID, Name, Outline_Level, Start_Date, Finish_Date"
> Any help would be appreciated.
> Thanks,
> Paul
Hello,
Paul
I have had the same issue and have had little to no help from Epicor
Support
Anyone else?
Of arakawapaul
Sent: Tuesday, July 24, 2007 2:46 PM
Subject: [Vantage] Importing MS Project file
Hello,
Paul
