Importing Parts via Service Connect
This issue was resolved with the help of Daniel Laidig as noted below.
Worked perfect!
After you have created your schema mapping, drag a link from the root
part note on the left to the root part node on the right, while
holding down the ctl key. This should map a dotted blue line. The
dotted line means it is cycling.
Daniel Laidig
--- In vantage@yahoogroups.com, Safi Obaidi <idiabos@...> wrote:
> Thanks for the feed back Tom! Unfortunately, I don't have the SC
student manual... :(
> From: "Moore, Tom" <tmm@...>
> To: vantage@yahoogroups.com
> Sent: Monday, November 10, 2008 8:38:32 AM
> Subject: RE: [Vantage] Importing Parts via Service Connect
> The service connect student manual page 42.
> Note that the Row node is connected to the Part node to ensure that each
> row is treated as an individual item.
> If this is not done then the sample workshop will only process one
> record.
> Tom Moore
> ____________ _________ _________ __
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
> Of idiabos
> Sent: Friday, November 07, 2008 2:05 PM
> To: vantage@yahoogroups .com
> Subject: [Vantage] Importing Parts via Service Connect
> Hello - I am new to SC and Vantage for that matter. I am trying to
> upload all my parts library into Vantage using Service Connect. I
> have created the Workflow and everthing connects properly. However, my
> workflow is only uploading one line of my data file(.csv). It doesn't
> load the second or the remaining lines. Am I missing something? Thanks!!
> This e-mail transmission and any attachments to it are intended
> solely for the use of the individual or entity to whom it is
> addressed and may contain confidential and privileged
> information. If you are not the intended recipient, your use,
> forwarding, printing, storing, disseminating, distribution, or
> copying of this communication is prohibited. If you received
> this communication in error, please notify the sender
> immediately by replying to this message and delete it from your
> computer.
When you imported your csv schema file into Service Connect, it has to have
multiple parts. If your original schema only has one line, then it thinks
your csv file will only have a single line.
Daniel Laidig
Laidig Systems, Inc.
(574) 256-0204 ext. 229
<mailto:daniellaidig@...> daniellaidig@...
idiabos
Another option would be to call it on a subworkflow that cycles through the list.
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
513-716-6400 (direct)
513-382-3281 (cell)
513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@01C940EB.B62A5690]
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Daniel Laidig
Sent: Friday, November 07, 2008 2:10 PM
Daniel Laidig
<mailto:daniellaidig@...<mailto:daniellaidig%40laidig.com>> daniellaidig@...<mailto:daniellaidig%40laidig.com>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
idiabos
Its most likely down to the fact that you haven't setup your cycling
properly...
I dont know how your workflow has been written, but I always approach
this with a main and a sub workflow. ( if you just have a single
workflow, I dont think the looping will work ). The main workflow is
configured to call the sub workflow for every part in your csv file.
I usually import from Excel, and it doesn't matter whether there is 1
line or 100 lines in the input file as this information is not held
in the schema.
You should also check your outbound messages to ensure that the
routine has finished without an error.
I hope this helps...
Best regards,
Nick
--- In vantage@yahoogroups.com, Michelle de la Vega <mdelavega@...>
through the list.
> Michelle de la Vega
> Cold Jet, LLC
> 513-382-3281 (cell)
> 513-831-1209 (fax)
> [cid:image001.jpg@...]
to have
thinks
> Daniel Laidig
Behalf Of
> idiabos
my
doesn't
Thanks!!
record.
Tom Moore
Of idiabos
computer.
Thanks for the feed back Tom! Unfortunately, I don't have the SC student manual... :(
record.
Tom Moore
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of idiabos
computer.
