In the Epcior ERP How we can fetch the Fresh JOB , that not started
"https://epicor-dev./E10Test/api/v2/odata/OCM14091/Erp.BO.JobStatusSvc/$metadata#JobStatus/$entity"JOB FROM ERP
What the Attributes In Meaning in ERP of Epcior
SchedStatus
JobHeld
Plant
JobReleased
WIStartDate
WIDueDate
SchedStatus - Assuming this is whether the job is scheduled or not.
JobHeld - You can place a job on Hold, though, it may just be a visible “Flag” and not prevent anything in the system unless you wire up some BPMs based on the flag status.
Plant - The site the job is for.
JobReleased - true/false. Time entries cannot be placed on jobs that are not released.
WIStartDate/DueDate - These are “what if” dates utilized by the scheduling engine. So if you move a job around on the scheduling board it uses the what-if dates to recalculate scheduling operations, material requirement due dates, etc.
I recommend looking at the help documentation within the system and/or field help to learn more about specific fields.
Thanks for the clarification.
We need your help in understanding the attributes of the Epicor ERP system. Below are the fields and related queries that need clarification:
  1. Fresh Job Identification
  • we must fetch newly created jobs from the ERP system. However, we are unable to identify any attributes that can be used to determine if a job is freshly created. Could you suggest the relevant attribute(s) or approach to identify fresh jobs in the system?
  1. Job Department Association
  • We need to determine which department a job belongs to. Could you provide guidance on the attribute(s) or methodology we should use to ascertain the department associated with a specific job?
  "@odata.context": "https://*******/E10Test/api/v2/odata/OCM14091/Erp.BO.JobStatusSvc/$metadata#JobStatus/$entity",
  "Company": "OCM14091",
  "JobClosed": false,
  "ClosedDate": null,
  "JobComplete": false,
  "JobCompletionDate": null,
  "JobEngineered": true,
  "JobReleased": true,
  "JobHeld": true,
  "SchedStatus": "R",
  "JobNum": "022983",
  "PartNum": "SBU200-P",
  "RevisionNum": "1",
  "DrawNum": "",
  "PartDescription": "SLAB BOLSTER UPPER - 2'' HEIGHT - PLAIN - 5000/FT SKID",
  "ProdQty": 100000,
  "IUM": "FT",
  "StartDate": "2024-02-09T00:00:00-06:00",
  "StartHour": 0,
  "DueDate": "2024-02-09T00:00:00-06:00",
  "DueHour": 0,
  "ReqDueDate": "2024-02-09T00:00:00-06:00",
  "JobCode": "",
  "QuoteNum": 0,
  "QuoteLine": 0,
  "ProdCode": "1000",
  "InCopyList": false,
  "WIName": "",
  "WIStartDate": "2024-02-09T00:00:00-06:00",
  "WIStartHour": 0,
  "WIDueDate": "2024-02-09T00:00:00-06:00",
  "WIDueHour": 0,
  "SchedCode": "NORMAL",
  "SchedLocked": false,
  "ProjectID": "",
  "WIPCleared": false,
  "JobFirm": true,
  "PersonList": "",
  "PersonID": "",
  "ProdTeamID": "",
  "QtyCompleted": 50000,
  "Plant": "MfgSys",
  "DatePurged": null,
  "TravelerReadyToPrint": false,
  "TravelerLastPrinted": "2024-01-29T00:00:00-06:00",
  "StatusReadyToPrint": false,
  "StatusLastPrinted": null,
  "CallNum": 0,
  "CallLine": 0,
  "JobType": "MFG",
  "RestoreFlag": "",
  "PhaseID": "",
  "AnalysisCode": "",
  "LockQty": false,
  "HDCaseNum": 0,
  "ProcessMode": "S",
  "PlannedActionDate": "2024-02-09T00:00:00-06:00",
  "PlannedKitDate": "2024-02-09T00:00:00-06:00",
  "MSPTaskID": "",
  "MSPPredecessor": "",
  "UserMapData": "",
  "ProductionYield": false,
  "OrigProdQty": 100000,
  "PreserveOrigQtys": false,
  "NoAutoCompletion": false,
  "NoAutoClosing": false,
  "CreatedBy": "dbrown",
  "CreateDate": "2024-01-29T00:00:00-06:00",
  "WhseAllocFlag": false,
  "OwnershipStatus": "",
  "PDMObjID": "",
  "ExportRequested": "",
  "SplitMfgCostElements": false,
  "XRefPartNum": "",
  "XRefPartType": "",
  "XRefCustNum": 0,
  "BasePartNum": "",
  "BaseRevisionNum": "",
  "RoughCutScheduled": false,
  "EquipID": "",
  "PlanNum": 0,
  "MaintPriority": "",
  "SplitJob": false,
  "NumberSource": true,
  "CloseMeterReading": 0,
  "Forward": false,
  "SchedSeq": 0,
  "PAAExists": false,
  "DtlsWithinLeadTime": false,
  "GroupSeq": 0,
  "RoughCut": true,
  "PlanGUID": "",
  "PlanUserID": "",
  "LastChangedBy": "",
  "LastChangedOn": null,
  "EPMExportLevel": 0,
  "JobWorkflowState": "",
  "JobCSR": "",
  "ExternalMES": false,
  "SysRevID": 898030776,
  "SysRowID": "a9f04876-f5dd-4b5d-a2fc-c51a589cbf54",
  "LastExternalMESDate": null,
  "LastScheduleDate": null,
  "LastScheduleProc": "",
  "SchedPriority": 0,
  "DaysLate": 0,
  "ContractID": "",
  "ProjProcessed": false,
  "SyncReqBy": false,
  "CustName": "",
  "CustID": "",
  "IsCSRSet": false,
  "UnReadyCostProcess": false,
  "ProcSuspendedUpdates": "",
  "ProjProcessedDate": null,
  "PCLinkRemoved": false,
  "ExternalMESSyncRequired": false,
  "ExternalMESLastSync": null,
  "EpicorFSA": false,
  "AdvanceLaborRate": false,
  "dspReadyCostProcess": false,
  "EnableJobEngineered": false,
  "EnableJobFirm": false,
  "EnableJobReleased": false,
  "EnableMaterialStatus": false,
  "EnableProject": false,
  "EngineerAllowed": false,
  "EquipLocDesc": "",
  "ExtUpdated": false,
  "FinalOpDueDate": null,
  "FirmProcEnable": false,
  "FirmProcess": false,
  "HasPlanAsAsm": false,
  "HeaderSensitive": false,
  "IgnoreMtlConstraints": false,
  "JobTypeName": "",
  "KitTime": 0,
  "LockedQty": false,
  "NewMeter": 0,
  "OldJobNum": "",
  "OrderQty": 0,
  "PartmasterPart": false,
  "PhaseDescription": "",
  "PMJob": false,
  "ProcessModeDescription": "",
  "ReceiveTime": 0,
  "SmartString": "",
  "SmartStringProcessed": false,
  "SOExists": false,
  "StockQty": 0,
  "ToFirm": false,
  "XRefPartTypeDesc": "",
  "ChangeDescription": "",
  "ClearDataset": false,
  "IsCoPart": false,
  "BitFlag": 8,
  "AnalysisCdDescription": "",
  "CallLineLineDesc": "",
  "EquipMeterUOM": "",
  "EquipSerialNum": "",
  "EquipLocID": "",
  "EquipPlant": "",
  "EquipDescription": "",
  "EquipBrand": "",
  "EquipModel": "",
  "EquipCurrentMeter": 0,
  "EquipTypeID": "",
  "EquipOEM": "",
  "ExpenseCodeDescription": "",
  "HDCaseDescription": "",
  "PartNumSalesUM": "FT",
  "PartNumIUM": "FT",
  "PartNumTrackLots": false,
  "PartNumPartDescription": "SLAB BOLSTER UPPER - 2'' HEIGHT - PLAIN - 5000/FT SKID",
  "PartNumTrackSerialNum": false,
  "PartNumTrackDimension": false,
  "PartNumSellingFactor": 1,
  "PartNumPricePerCode": "E",
  "PartNumLocationIDNumReq": false,
  "PersonIDName": "",
  "PlantName": "OCM Manufacturing",
  "PlantMaintPlant": "MfgSys",
  "ProdCodeDescription": "SBU - PLAIN DOM",
  "ProdTeamIDDescription": "",
  "ProdTeamIDName": "",
  "ProjectIDDescription": "",
  "QuoteLineLineDesc": "",
  "QuoteNumCurrencyCode": "",
  "SchedCodeDescription": "NORMAL",
  "RowMod": ""
