I have created a dashboard to group by Key1 to make it easy for user to get
to there data. I made a couple of tweaks to the code just to remove the
Corvu name in the status.
Thanks again!
Steve
Sent: November 18, 2008 8:08 AM
Subject: [Vantage] Re: Indented BOM Cost report
You are welcome. We use the data with CorVu so not many fields are
used in UD20, but you can populate as many fields with whatever you
need for use with a BAQ pretty easily.
We have multiple users using the 'tool' that is why Key1 is the
userid. - to keep each persons data separate.
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
Thanks again!
Steve
>BOM
> BW,
> Thanks for the upload!! I can find many uses for the utility.
> Steve
> From: bw2868bond [mailto:bwalker@...]
> Sent: November 15, 2008 2:25 PM
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> I created a customization to UD20Entry that populates UD20 with a
> and a summarized BOM - we use it with CorVu for quoting materials,40yahoogroups.com> .com, "Brian
> costs etc.
> I think it should be possible for the data to be used in a BAQ,
> joined to what ever tables needed and then sent to Crystal.
> I can upload to files section if anyone is interested.
> bw
> W, Spolarich" <bspolarich@>part
> wrote:
> > This is on my to-do list right now: develop a custom BOM report
> that shows
> > costs. It is quite possible to do this in Crystal if you have
> MSSQL 2005 on
> > the backend.
> > -brian
> > On 11/12/08 10:06 AM, "Jasper Recto" <jrecto@> wrote:
> > > Has anybody recreated the Indented BOM Cost report in report
> builder, crystal
> > > reports or Microsoft access?
> > > I need to be able to run that report and filter out certain
> classes.[Non-text portions of this message have been removed]
> > > Any suggestions?
