Infinite logon with compile report
We had a couple of reasons why this happened to us.
We added a user name but no password to the odbc connection when we moved
from V3 to V4, this caused the same error as yours to occur. To fix this, we
had to set the location and verify all reports (and all subreports).
The other thing I have seen which causes this on one PC only, is odbc driver
corruption. Completely uninstall and re-install your odbc driver &
configuration on the client machine which causes the problem. Make sure
someone has not installed another odbc configuration in User DSN instead of
or as well as System DSN.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, February 05, 2002 5:30 AM
Subject: [Vantage] Infinite logon with compile report
> we used crystal 7 to make a compiled report.
> The problem we are having is that once we hit the
> print button We give the password and it starts a loop
> asking us over and over asking for the password.
> we have verified the login information and pass to be
> correct. Is there any way around this problem?
> We need to print a receiving report and epicor did
> not include this.
> __________________________________________________
> Do You Yahoo!?
> Great stuff seeking new owners in Yahoo! Auctions!
> http://auctions.yahoo.com
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
not include this.
Do You Yahoo!?
If you hit PrintPreview first, can you print the report?
Troy Funte
Liberty Electronics
Sent: Monday, February 04, 2002 2:00 PM
not include this.
Do You Yahoo!?
Yahoo! Groups Sponsor
We sometimes get this situation. It usually happens after we've installed a
service pack to NT4.0 or W2K. We just reinstall the ODBC driver and make
sure it's setup properly. The setup must be done for each user that will
run CR from that workstation.
Warren R. Eddy
Information Services Manager
National Tube Form
A Leggett & Platt Company
Phone: (219) 478-2363 ext 217
Fax: (219) 478-1043
Warren.Eddy@...
Sent: Monday, February 04, 2002 2:01 PM
not include this.
Do You Yahoo!?
