Initial Inventory Load
Yes, the interface is turned on.
Of Jim Frice
Sent: Friday, December 14, 2007 5:09 PM
Subject: RE: [Vantage] Initial Inventory Load
Is the inventory interface turned on?
Behalf
Of Manasa Reddy
Sent: Thursday, December 13, 2007 3:44 PM
Ok Accounting gurus, tell me if I am wrong in saying this but if you
adjust the cost of a part through cost adjustment then those costs will
hit the GL only after you have done some kind of inventory transaction.
In otherwords, if you did some cost adjustments, then did some inventory
transactions, then run the COS/WIP, then those costs will hit.
Did you do all of this?
M. Manasa Reddy
manasa@... <mailto:manasa%40weldcoa.com>
P: 630-806-2000
F: 630-806-2001
Behalf
Of Michelle C. Grman
Sent: Thursday, December 13, 2007 3:10 PM
I was looking at the material transaction detail report and on the GL
after I ran the COS/WIP activity report.
Behalf
Of Manasa Reddy
Sent: Thursday, December 13, 2007 3:02 PM
What were you looking at when you saw that the cost was not generated?
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Sent: Thursday, December 13, 2007 12:41 PM
Subject: [Vantage] Initial Inventory Load
We are preparing to go live in Vantage 8.03.403C, we plan on using the
Quantity Adjustment to load the initial inventory quantities. How does
the initial cost in the sub ledger get loaded? I entered standard unit
costs for finished goods in the Cost Adjustment, and no cost was
generated with the Quantity Adjustment.
Michelle C. Grman
Assistant Controller
KERUSSO
The Greek word means - To herald divine truth as a public crier; to
preach the gospel.
P.O. Box 32
Berryville, AR 72616
Phone: 870-423-6242 Ext. 222
Fax: 870-423-3568
Web Site: www.kerusso.com
Revolutionize your jewelry sales with the Beacon Accessory Center:
"The Beacon is a SERIOUS MARGIN MAKER! We've sold half of the product in
less than a month!"
-Ron Kuzman, Mgr., Sonrise Christian
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
We are getting ready to go live with Vantage 8.0.3... I do not see an
inventory load option under set-up, like there is for open invoices.
How does the initial inventory quantities get loaded? Is there a load
program somewhere?
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Fax: 870-423-3568
less than a month!"
at: 800-424-0943
To run an initial Inventory Load you will need to have a custom
program written and it is worth the expense. The best place to
purchase a custom program like that is from 2W Technologies. They
already have it written. So you can get it right away. They are an
Epicor authorized support group. Call (814)333-3117 - Hope this
helped - Monte Tomerlin
--- In vantage@yahoogroups.com, "Michelle C. Grman" <mcgrman@...>
an
load
> program somewhere?
> Michelle C. Grman
> KERUSSO
> preach the gospel.
> P.O. Box 32
> Fax: 870-423-3568
product in
> less than a month!"
> at: 800-424-0943
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Fax: 870-423-3568
less than a month!"
at: 800-424-0943
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Fax: 870-423-3568
less than a month!"
at: 800-424-0943
Are the parts set up as average cost for sure? Did you set up the
adjustment reason for the correct account number?
Of Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Fax: 870-423-3568
less than a month!"
at: 800-424-0943
Of Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Fax: 870-423-3568
less than a month!"
at: 800-424-0943
When we loaded our inventory for a fresh install of Vantage 8.0, we
created wash transactions that credited and debited the same account
so that no costs hit the GL but the inventory is put in the right
place. To do this, you need to modify either the reason code account
to match your inventory account or visa versa. You should definitely
see the transactions on COS/WIP as long as you specified the right
report parameters (date range, not posted, ect).
The more difficult task was loading WIP accounts. You had to do the
same thing with Job Adjustments matching the direct labor, direct
materials, burden, etc accounts to the WIP account (based on product
group). It all had to be carefully orchestrated and verified after
each transaction.
Good luck.
> Of Manasa Reddy
> M. Manasa Reddy
> P: 630-806-2000
> F: 630-806-2001
> Behalf
> Michelle C. Grman
> KERUSSO
> preach the gospel.
> P.O. Box 32
> Fax: 870-423-3568
> less than a month!"
> at: 800-424-0943
The costing method is equal to Std in the Part Maintenance, and I
entered a Standard Unit Cost in the Cost Adjustment before I did the
Quantity Adjustment. I set up a reason code of Initial Inventory Load
and pointed that reason to the Finished Goods on the GL.
Of Jim Frice
Behalf
Of Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Fax: 870-423-3568
less than a month!"
at: 800-424-0943
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Behalf
Of Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Fax: 870-423-3568
less than a month!"
at: 800-424-0943
I sent this yesterday afternoon, I have no idea why it did not show
up....
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Behalf
Of Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Fax: 870-423-3568
less than a month!"
at: 800-424-0943
Of Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Behalf
Of Manasa Reddy
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Fax: 870-423-3568
less than a month!"
at: 800-424-0943
